Modding Painting and polishing case inside
Discussion in 'Modding' started by Morphious, 16 Sep 2004.
  1. Morphious
    Morphious What's a Dremel?
    19 Jan 2004
    Are there any special precautions I need to take for painting the inside of my case?
    Also, if I just have plain metal (I'm making the case myself) should I do anything to the metal? I know that I need to polish it - something that I don't know how to do yet but will have some of my friends help me out with - but do I need to put a clearcoat on it afterwards or anything?
    Thnx.
  2. dannyqball
    dannyqball What's a Dremel?
    22 Apr 2004
    http://forums.bit-tech.net/showthread.php?t=48393
    I'm sure you could use the same technique as this person. if you use the wax then you won't have to worry about some messy sticky clear coat. I bet it would work well and look great for a long time.
    I'm actually thinking about doing it with one of my mini towers.
  3. Morphious
    19 Jan 2004
    What if I don't have access to a dremel? What other alternative tools could I use?
  4. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    you can use basicly anything you want heck you *could* do it by hand it you wanted, would just a long time, other machines, you can use a dril with the right attachment, it chouldn't matter what tool you use as long as you got a polishing attachment you will be fine, cause with that you can use so many different tools but if you don't have a Dremel i'de suggeust using a drill
  5. dannyqball
    22 Apr 2004
    I just peeled the stickers off of a hd yesterday, I took some citrus solvent to get the glue off and then polished it by hand, it already shines like a mirror and I haven't even waxed it yet or used a dremil.
