Modding Painting case..
Discussion in 'Modding' started by Fusen, 15 Feb 2004.
  1. Fusen
    Fusen New Member
    17 Jan 2004
    I've decided that I want to paint my normal run of the mill case into a ncie shiny metal blue, my mate has a ncie spray gun I can sue but I need to know what sort of paint to use and do I need special stuff to protect the paint afterwards? any help will be greatly appreciated
  2. coffindodger
    coffindodger New Member
    6 Feb 2004
    i've just painted my case using Halfords car paints and primers.
    in short you need to prepare the surface, prime it, paint it and then finish of with acrylic varnish. tTaking your time is good.
    You can find a more comprehensive guide Here
    Good luck
