SketchUp painting parts
Discussion in 'Modding' started by disturbed13, 24 Jan 2010.
  1. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    okay
    im having a hard time getting a piece of plexiglass to be clear instead of blue
    is there anyway to fix that?
    and how do you paint parts to make them look like black metal
    apparently there is something that im missing
    anyone have any links for me?
    or a tutorial?
    any help is greatly appreciated
    thanks
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    In the materials panel, under the Edit tab, move the color wheel to the center (white) and the opacity to 0.
    For the metal, go the metal (whatever one you want), under the Edit tab, and move the color wheel to the center and move the slider bar to the bottom to get black
    Hope this helps
  3. disturbed13
    28 Nov 2008
    mine wont let me do that
    is there a reason why that you know of?
  4. jhanlon303
    7 Sep 2006
    Your version please?
  5. disturbed13
    28 Nov 2008
    its 7.1
    i just had to be smarter then the cookie jar
    i figured it out
    thanks for the replys guys
