Modding painting question??
Discussion in 'Modding' started by s002wjh, 21 Dec 2007.
  1. s002wjh
    s002wjh What's a Dremel?
    6 Dec 2007
  2. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    the cheap way would be a case vinyl, the expensive or harder route would be to air brush it, which it probably is. I know nothing about painting, but from that i can tell its airbrushed, and thus thats why its soo expensive since it can not be reproduced easily by a machine. With a airbrush you can lower and raise air pressure, thus putting more paint on certain areas and making them more visible, the lower the pressure im guessing, the less paint, thus the more transparent look you get. Don't quote me on any of this, but that's what i think. Unless your willing to fork your case over and some $$$ to have it custom painted or to buy a pre-painted one, or if you can do that yourself, your best bet will be a case vinyl, and i have no idea where you would go about looking for one of those. Hope this helps.
  3. s002wjh
    6 Dec 2007
    darn i was hoping there is a way i can do this my self. guess not. any painter has any tips or guide?
  4. s002wjh
    6 Dec 2007
    is there a way to use spray paint to get that affect?
  5. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    this might help if you do choose to do vinyls instead of paint
    http://www.mnpctech.com/Blue_MetalFlake_Vinyl_Film.html
  6. s002wjh
    6 Dec 2007
    any place to buy or reading regarding vinyls?
  7. perkins teh modder
    8 Dec 2007
    i posted a link above, you can buy it there and they have a vid to show you how to put it on
  8. Naja002
    Naja002 What's a Dremel?
    22 Jan 2008
    Best place I have found is:
    MetroSellers Vinyl Express
    As many feet as You want......:thumb:
