Modding Painting the casing of a radiator
Discussion in 'Modding' started by Kronos, 5 Feb 2015.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
  2. Kronos
    Kronos Multimodder
    6 Nov 2009
    53 views and no one with any thoughts?
  3. jinq-sea
    15 Oct 2012
    Yes - but no time to set them out properly :thumb:
    I'll post something later?
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    Cheers mate. Look forward to them. Paint type also useful.
  5. bulldogjeff
    2 Mar 2010
    It's an easy job . rub down with something like a scotch bright cloth to key it up. give the rad a good clean after. Then under coat with white under coat, light coats are best. Leave over night to dry then a gentle rub with some 800 wet and dry. The top coat in gloss paint.. Job done.. Use some laquer as a final coat if you want.
    If you want have a look though my builds you can see the process i go through when I'm spraying cases etc.
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    Will do mate thanks.
  7. jinq-sea
    15 Oct 2012
    I know that Custom PC did an article on this recently, Glenn - I just haven't had a minute this evening to dig it out. I'll see if I can locate it tomorrow for you!
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    Cheers Sam.:thumb:
