Modding Painting The Tray????
Discussion in 'Modding' started by duggyb, 11 Feb 2005.
  1. duggyb
    duggyb What's a Dremel?
    8 Feb 2005
    hey i just took apart my CD Rom and DVD Rom and decided to paint the bezels but i was also wandering will it hurt anything if i spary paint the cd trays as well??
    THNX
    Duggy :dremel:
  2. TheMuffinMan
    TheMuffinMan Minimodder
    26 Apr 2004
    I haven't had any problems with my xbox drive being painted, just make sure it's completely dry and you don't have globs of paint on it, or it can screw it up (cd being stuck to tray haha or too much paint slowing it down)
  3. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    You can paint the tray without problem, but I would highly recommend you pick up some vinyl dye for it instead of regular spray paint. It's much thinner and will wear better. You can get vinyl dye at any walmart or similiar place, its with all the rest of the spray paint.
  4. Skylined
    Skylined Minimodder
    3 May 2003
    Yeap, Vinyl Dye is a lot better and easier to use when you're working with plastics.
    One thing though, I wouldn't dye the part where the CD rests.
  5. Shadowspawn
    1 Jul 2002
    He can dye that part. When the cd spins it's not actually resting on the tray anymore. The internal parts lift the cd up while its being read. The only time the cd rests on the tray is during closing and opening and the dye can resist that little bit of wear for awhile.
  6. duggyb
    8 Feb 2005
    ok so what is the best type of dye to buy??
    and what does it look like is it in a can or what??
    ill add it to my list for next time i am in the city
    THNX everyone
    Duggy :dremel:
  7. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Personally i like PlastiKote, quick drying and has a great finish :D
