Modding Painting Touch Pad?
Discussion in 'Modding' started by bluknight, 23 Feb 2006.
  1. bluknight
    bluknight New Member
    4 Jul 2005
    Hey, I was just wondering if it's a good idea or a :wallbash: type of idea to paint a touchpad. I'm not entirely sure how touchpads work, but if they work how I am thinking, i don't think a thin layer of paint would hurt it.
    (I'm planning on modding my laptop)
  2. mattthegamer463
    mattthegamer463 New Member
    26 Nov 2004
    I doubt if it would hurt it, but it might make it less responsive to your touch, and if I remember correctly they bend a bit when you press them, which might cause the paint to crack and peel off. I don't think its a very good idea to paint one of those.
  3. ajack
    ajack rox
    17 Apr 2003
    I personally wouldn't do it - they're pretty sensitive and painting over it will prolly make it less responsive. They're heat sensitive too (iirc - hence why you can't use a pencil etc) so a layer of paint isn't going to conduct much heat...
  4. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    most touchpads are capacitive they respond to the capacitance of your finger(which is why they dont work with pencils) dont know if it would work through paint though
    Moriquendi
  5. Damske
    Damske New Member
    13 Jan 2006
    If you have a look at the new Ipod Videos you'll see that their touch pads work through the protective case they provide (about a 2mm thick suede? case). So I'd say it'd probably work. That said don't come knocking on my door if it doesn't... :D
  6. MightyMouse
    MightyMouse New Member
    21 Mar 2005
    Not that I've tryed or anything. But if it works through the protective caseing, it probly should work through one of those latex thingys with pictures on it. Like the kind you can get as case wraps.
    Would be a killer mod if it works, and if it doesnt it shouldent be too hard o peel it off again.
  7. Confused Fishcake
    Confused Fishcake New Member
    25 Sep 2005
    Trouble is, the material they use is low-friction, not all paint is.
  8. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    if you do paint it, use vinyl dye, because that is absorbed into the plastic rather than forming a layer on top of it. it should preserve the texture of the surface much more so than normal lacquer, and also result in a much more responsive pad.
  9. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Did anybody see the toshiba laptop on sale a while ago (probably bout 18months now)?
    It had a small lcd display behind the touchpad to display a logo or similar. Was a pretty good idea.
    The problem with using vinyl dye is: if it goes wrong, there's no turning back as it is absorbed into the plastic.
  10. mattthegamer463
    26 Nov 2004
    Cant you just redye it again?
  11. ozstrike
    19 Sep 2004
    As in, if you paint it and it stops the touchpad working, you can just peel the paint off (probably), but if the vinyl dye messes it up, then you can't get it off (I don't think)
  12. Cadillac Ferd
    Cadillac Ferd New Member
    11 Oct 2005
    Won't the paint wear off with use? That seems like that would mean that even if it did work your little modjob would get ruined fast.
