My HTPC is using a GeForce FX 5200 (more than sufficient to watch DVDs) card with the drivers currently set to PAL output, which is fine, but I prefer the reduced flicker (but not the fuzziness) of NTSC. When I still had a GeForce2 I used to have a program called TVtool to enable PAL60 mode (PAL resolution at 60Hz), unfortunatly that option is greyed out when using TVtool with the GeForce FX. Is there a way to natively enable that mode in the driver?
