Graphics Palit 6600GT or PowerColor 9800pro
Discussion in 'Hardware' started by quadmodz, 10 Oct 2005.
  1. quadmodz
    quadmodz What's a Dremel?
    9 Oct 2004
    can you guys help me?
    which 2 of that is the best?
    Palit 6600GT 128mb 128bit 8x AGP
    or
    PowerColor 9800pro 128mb 256bit 8x AGP
  2. Tim S
    Tim S OG
    8 Nov 2001
  3. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    No, the 6600Gt is still a pretty decent card tbh. :)
    Work wonders at 1280x1024 and under.
  4. quadmodz
    9 Oct 2004
    so what's the best? lol. Im Silly now. hahaha. please help me.
    I've search that they have the same performance. On the 6600gt the only thins is that the performance is best but on the AtI 9800 is about on the display.
  5. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    im pretty sure the 6600gt will be better
  6. quadmodz
    9 Oct 2004
    thanks bro! :)
  7. alastor
    alastor Minimodder
    6 Sep 2004
    Theres always this as well, which is miles better than either and probably about the same money...if the sell it in the Philippines that is.
  8. Tim S
    Tim S OG
    8 Nov 2001
    that's on PCI-Express though, the guy is looking for an AGP card. The 6600 GT rules the rooster on AGP for the time being.
  9. chemo
    chemo True Jungle Brother
    20 Feb 2005
    6600gt all the way, ive had both and can tell you that at lower res's the performance is much better on the nvidia
  10. Hazza
    Hazza What's a Dremel?
    25 Nov 2003
    what about a 6800? You can get those for AGP about the same price as a 6600GT and you can try and unlock some pipelines :naughty:
  11. chemo
    20 Feb 2005
    ^nice one.
    even if you cant get the full 16x6 running, the 12x5/6 would be better than the 6600gt, again ive had a 6800nu :)
  12. nerozero
    nerozero What's a Dremel?
    11 Oct 2005
    I just found this site and it looks like another good one. i have the 6600GT and i love it. i am curious what you meaning by unlocking pipelines. how do you do that? and what is the max temp for the 6600GT without being dangerous? i am usually steady at about 63C Loaded for hours OCed just a little. how high can i go safely?
  13. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    This makes me want to ask a question. Buying a new agp card now, what's the best bet? 6600gt, 6800, or one of them fancy x*** ati cards?
  14. nerozero
    11 Oct 2005
    i am very satisfied with my 6600GT but i have never used a 6800
    i have mine at 525 core and 1.15Ghz memory speed atm
  15. Hazza
    25 Nov 2003
    X800GT's are supposed to be very good for the money, especially the IceQ TURBO ones. A 6800 or 6800LE (otherwise 6800NU) has some pixel pipelines and vertex shaders locked off. These can be unlocked by softmodding http://forums.bit-tech.net/showthread.php?t=94812 so that the card has as many pipelines as say a 6800GT.
    For Example: A 6800LE has 8 pixel pipelines and 4 vertex shaders. The NV40 chip has upto 16 pixel pipelines and 6 vertex shaders, which can be unlocked. Sometimes a couple of pipelines are faulty (which is why they have been locked) so you can't use all 16*6, but this is not always the case. Either way, you can still normally get something extra out of an AGP 6800.
    I dont know if X800GT's can be softmodded but i suspect they can. I'm pretty sure 6600GT's can't be because they are different chip to the 6800's (6600's are NV43 whereas 6800's are NV40). 6600GT is the most you can possibly get from that particular chip in terms of pipelines.
  16. alastor
    alastor Minimodder
    6 Sep 2004
    :p
  17. Tim S
    Tim S OG
    8 Nov 2001
    My bad, I wasn't aware that they were bringing X800GT* to AGP as well :blush:
  18. alastor
    alastor Minimodder
    6 Sep 2004
    Me neither until I found that, its not even listed on the Gecube website, but its definitely AGP from the picture, if thats really it of course. It does have the GT* heatsink...
  19. LoneArchon
    LoneArchon What's a Dremel?
    15 Jun 2004
    Sapphire makes a x800gto 256mb agp model.
  20. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    Sorry for the hi-jack but it isnt worth a new thread. Would that card be worth getting as ive got agp and im getting confused what is the best at the moment. looking to spend around less than £150 on a reasonable card.
    thanks
