Modding Panaflo Fans Cheap (UK)
Discussion in 'Modding' started by PQuiff, 5 Oct 2004.
  1. PQuiff
    PQuiff What's a Dremel?
    7 Sep 2001
    Get some really cheap Panaflo fans: everything from 40mm up to 120mm
    I ordered a 120mm and i got it the next day good service....
    http://www.dorothybradbury.co.uk/
  2. mushky
    mushky gimme snails
    24 Mar 2003
    I've been buying fans from her for a while now. Always great service and the fans are good too.
  3. nazikiller
    nazikiller What's a Dremel?
    7 Oct 2004
    Same here. Always an exellent service.
  4. Boon
    Boon What's a Dremel?
    2 Sep 2002
    Ypu always buy my fans from there.. no problems with service.
  5. Guest-16
    Guest-16 Guest
    She's a member of our forums even :D
    Quality service and good prices. Plus its one of the ONLY places to buy them in the uk.
  6. ChegsJAR
    ChegsJAR What's a Dremel?
    7 Sep 2003
    yeah I have brought from her too
    good fans and come really quickly
  7. danyp63
    danyp63 What's a Dremel?
    4 Nov 2004
    Yer I have bought a couple of fans from there aswell, only place in the UK to stock them I think, really good service, both orders recieved next day.
    Superb :D
  8. Nexxo
    23 Oct 2001
    Bookmarked. :thumb:
  9. richard-wong
    richard-wong What's a Dremel?
    6 Aug 2004
    antec's fan is better, slightly less CFM, but a lot quieter, for 120mm
  10. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Have you tested them in a case or are you going by manufacturer’s statistics? The 120mm Panaflo in my case is the quietest fan I've had (and I undervolt all my fans) it also works well at low voltage (whereas some do not start or have a pronounced whir or rattle) and its fairly cheap considering the quality.
  11. PQuiff
    7 Sep 2001
    WORD!!!!
    go go mighty panaflo....
  12. richard-wong
    6 Aug 2004
    can't say i have tested it, but my antec fan works very well at 7volts and also i usually put it on monitoring very quiet!
  13. blknoel
    blknoel What's a Dremel?
    14 Jun 2004
    Too bad she doesnt ship old school Panaflo anymore, they are rebadged as NMB-MAT now, different specs too.
    How I now realise I need a 80mm H1A ='( ! cant find anywhere in the UK anymore.
  14. specofdust
    specofdust Banned
    26 Feb 2005
    I don't mean to offend, but try kitting out your PC with the things, those are not cheap. Maybe cheap compared to other options, but definately not cheap.
    To kit out a stacker case, would cost me about £100. Doing that with generics or even just not highcost fans I could do it for under £40.
    Good shop though, and one of, if not the only panaflow supplier in the UK.
  15. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    The specs should be the same... NMB-MAT and Panasonic merged in 2004 so you should be getting the same fan.
  16. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Look, Dorothy B is an excellent source of quiet fans, she also cherry-picks the best for low-noise for the home user and sells the less worthy to lesser demands, but this isn't Bargain Bin material tbh. :nono:
    Post in BB when she has a Sale on.
    And if you really want to know what makes fans tick and the truth about Chinaflo v Japaflo, read her posts (jafb2000) in this thread, highly informative.
    Since when has that been a consideration? Or do you buy expensive circuit boards and put them in a rattly tin can with a generic psu to save a few bucks? These days people often use a sound system on the PC, they don't want a hair-drier running in the background.
    Moving to Modding.
  17. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    Since ever, that is the law of computer suply. People buy Q-tec's, connect ultra-x and all sorts of crud because its flashy or cheap.
    People always cut corners in the PSU area :sigh:
    Theres a thread over at fm where somebodys connect ultra-x (that modular that everyone seems to think is somehow decent) has blown out and taken hardware too.
  18. specofdust
    specofdust Banned
    26 Feb 2005
    I understand what you're saying, but the title of the thread "Panaflow Fans Cheap" - well, when you follow the link and to deck your case out in fans costs over £100, that ain't cheap. Just me nitpicking though :)
  19. Nexxo
    23 Oct 2001
    You are. They are cheap for Panaflo fans.
    You want cheap-ass, go to PC-World. :D
  20. specofdust
    specofdust Banned
    26 Feb 2005
    Ah PC-World, if only they gave me a staff discount for having a PC-World T-shirt...its not my fault I ended up with it, I didn't ask to pay my brother £5 to get one for me just so I could confuse the customers :D
