Case Mod - In Progress Paradyse eXtreme
Discussion in 'Project Logs' started by Cyril06, 19 May 2011.
  1. Guest-89078
    Guest-89078 Guest
    It'd probably survive on the 115V they get in America, but the 230V we get over in Europe would probably fry it or blow your fuses or something :(
    Also, triangle?
  2. Cyril06
    Cyril06 paradyse.conception
    13 Aug 2010
    I check it, mine is in 220/230 V. So it's fine ;)
  3. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    i cant bileve that this awsome projectlog is on this side of the forum!
    Its a shame!
  4. Cyril06
    13 Aug 2010
    Thanks, but which side do you mean ?
  5. KoSoVaR^
    19 Dec 2010
    bit-tech.net Forums > Modding > Project Logs
  6. Cyril06
    13 Aug 2010
    If I'm right it's in : bit-tech.net Forums > Modding > Modding :)
  7. KoSoVaR^
    19 Dec 2010
    yes you are in the moddin section, you should be in the bit-tech.net Forums > Modding > "Project Logs" section
  8. Cyril06
    13 Aug 2010
    Oh yes you're right ! Wait & see, it doesn't really matter :)
  9. Cyril06
    13 Aug 2010
    New year ? New tools :)
  10. Cyril06
    13 Aug 2010
  11. Cyril06
    13 Aug 2010
    Watercooling loop is done. Need to buy some nice tubes now !
    Bitspower tank and fittings :
    Noiseblocker fan :
    Crappy temporary tubes and fans :D
    I have to use 2cm screws because the new PSU will be 2cm longer than this one ;)
    Need more Bitspower fittings to connect the radiator to the pump :
    Temporary tubing :
  12. KoSoVaR^
    19 Dec 2010
    looks very good so far :)!
  13. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I like the tubing even if it is not proper color.
  14. mally91
    mally91 What's a Dremel?
    21 Jun 2011
    looking good
  15. Cyril06
    13 Aug 2010
    Here are the last Bitspower fittings I need to end the watercooling :
    EK-Ekoolant UV Blue in Tygon tube :
    Test in the case to check if the color is good :
    Modification of the watercooling pump :
    Desoldering of old color cables :
    Cut 3 new cables in black :
    Facom automatic stripper in action :
    Soldering of the new cables on the pump :
    Crimps and black connector for a perfect finish :
    Crimping tool in action :
    All motherboard connectors are re-crimp and put on a single connector :
    And then they are sleeved together. Before :
    After :
    Bonus picture of the "shooting zone" :
    New Tamron 90mm macro lens :
    xMathiasD likes this.
  16. Cyril06
    13 Aug 2010
    Modification of the USB3 connector to fit in the motherboard USB2 header :
    Removing the differents shields :
    Only keep the 4 wires for the USB2 :
    USB pins and connectors :
    Crimping tool :
    Plug the terminals until you heard the "clic" :
    One done (above) :
    And the two are finished :
    Changing of the CPU waterblock jet plate :
    The old one (right) and the new (left) :
    Waterblock's maze and chipset's radiator :
    GPU waterblock :
    Sleeving :
  17. Briaireous
    Briaireous What's a Dremel?
    29 Nov 2011
    Very nice and very impressive camera skills :)
  18. Maximilian
    Maximilian WC Virgin
    31 Dec 2008
    Absolutely outstanding photography, looking great.
  19. Cyril06
    13 Aug 2010
    Thank you guys :)
    Noiseblocker PL-2 fan :
    Custom 3pin extension cables :
  20. Cyril06
    13 Aug 2010
    Today, working on PCI-Express cables for the GPU's :
    Here is the stuff for custom length cables :
    Wires are crimped and ready for sleeving :
    The first one is done :
    The second :
    And all the four cables are ended :
