Modding Parallel lcd that takes 12v?
Discussion in 'Modding' started by Phire, 15 Jul 2004.
  1. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    Ok so I recently acquired another HD44780 compatible lcd blah blah...but this one seems to want 12v to power up? Anyone ever seen this before? It is powered with a 3-pin connection so I am thinking either it takes 12v or that Dell used a riser with a +5v supplied 3-pin connection.
    pic:
    and another
    can you guess what color my entire system will be?
    side note: got it new for $5 shipped :D
  2. koola
    koola Minimodder
    11 Jul 2004
    That is real strange although it could source power from a motherboard fan power connector.
    I had a SED1520F that needed 12V from a fan power connector. It needed 12V because of the LEDs, they were ultra bright one that hurt your eyes in darkness lol.
    Anyways, hope you sort it :thumb:
  3. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    The 12V looks like it is for the backlight, and since that cable has 14 wires, I would think that is the case. Pins 1 and 2 on the cable are power for the LCD (1=gnd, 2=+5v) and pin 3 is contrast.
    If you disconnect that 3-pin header, than the LCD should still work, but the backlight should go out.
  4. Phire
    11 Jan 2002
    thanks for clearing that up! :D
  5. Penrhos
    Penrhos What's a Dremel?
    23 Oct 2001
    I got 5 of them in a box - pulled them out of Dell PE5133's that were going to the dump. they use standard pinouts and work with LCDC - replaced mine with a VFD from farnell.
  6. Phire
    11 Jan 2002
    you ever power up the backlights on them? I had this one on for about 5min and it seriously overheated and starting turning black. Luckily nothing was damaged but I am thinking it only takes 5v for the backlight.....
  7. Phire
    11 Jan 2002
    Orange.....w00t!
