Other Parcel 2 go
Discussion in 'General' started by bulldogjeff, 7 Oct 2011.
  1. bulldogjeff
    2 Mar 2010
    I need to send a case off. I know a few of you have used them in the past. They seem cheap enough, which makes me slightly weary....
    So are they any good would you recommend them...
    Any problems that you've had..
    Thanks in advance guys..:thumb:
    Teelzebub likes this.
  2. Krikkit
    21 Jan 2003
    They're fine. All they do is offer a portal to use various couriers, I've used them several times without any trouble. Another site to try is www.parcelmonkey.co.uk, same deal as P2G, used them as well and they're just the same thing.
  3. bulldogjeff
    2 Mar 2010
    I did notice the way they work, so it's just a case of fill out the on line bits and then some one turns up for collect the goodies..Seems simple enough
    Thanks Krikkit:thumb:
  4. saspro
    saspro IT monkey
    23 Apr 2009
    Parcel Monkey have a much better system for customer services.
    parcel2go generally just ignore emails for loss/damaged claims
  5. Teelzebub
    27 Nov 2009
    Use them all the time cheaper than RM in most cases and they pick it up from your house.
  6. bulldogjeff
    2 Mar 2010
    So over all, both recommended. Thats what I needed to hear. My main concern it that a large box gets picked up from my place and arrives some where else, quickly and in one piece.
  7. saspro
    saspro IT monkey
    23 Apr 2009
    I shipped that case to you with parcelmonkey, that got there safe
  8. bulldogjeff
    2 Mar 2010
    Ah, in that case I'll give them a try.
  9. MiT
    MiT Don't feed me after midnight!! nom
    18 May 2005
    I have used parcel2go, choose DHL, picked up from my work, delivered fine. Only used once for two parcels.
  10. Boardoombob
    Boardoombob What's a Dremel?
    11 Aug 2011
    I've used Parcel2Go a few times, and they're Ok (never had any issues with them, so I can't comment on the customer services).
  11. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    I have used them quite a bit just make sure you book with any courier apart from TNT as they are the worst for pick ups. I normally book with yodel (formally DHL) and city link who are very reliable
  12. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Whoever you book with, make sure it's not Yodel. Utterly crap. Matticus will agree here, abysmal service.
  13. flame696
    15 May 2009
    Weird that I've never had a problem with Yodel but TNT have been a pain i had to re-book 3 times before they collected
  14. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Been using them for years, absolutely fine IMO.
  15. Krikkit
    21 Jan 2003
    Let's not go down the "Oh, this carrier is crap" route, because every carrier has had bad customer service out there, and it's completely dependant on area too.
    I've had poor experiences (although nothing disastrous) with Parcel Force, UPS, City Link, FedEx and Yodel, but it doesn't stop me using them where necessary.
    Customer Service is a huge problem with large companies in the UK (and the world), and one where huge money savings are made by not having a large, competent CS department waiting for complaints to roll in. Hence when a parcel goes missing (or one of another million myriad problems with big business) you often find poor customer service under the surface, simply because the system hasn't been invested in.
  16. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    I'd personally recommend Interparcel over Parcel2Go. I've had to use each service's customer service departments. Interparcel handled my issue as I'd expect, in a quick and efficient manner, and didn't faff about reimbursing me (sent an FT02 - it arrived with one of the top cover's plastic hook things broken), and they refunded the postage cost too.
    Parcel2Go on the other hand. Used HDNL, who picked up the case 2 weeks late, then took nearly 2 weeks to deliver (this was apparently a 2 day service). Contacted Parcel2Go through the only channel open at the time (email), and was completely ignored.
    Needless to say, I recommend one and refuse to use the other now...
  17. Krikkit
    21 Jan 2003
    Another good one - Interparcel are the others I've used and pretty good too.
    Looking up their info, Parcel2Go.com are only in Bolton, so if you get stuck around the NW go and see them! (Doesn't help you in Maidstone though Marvin)
  18. integerspin
    integerspin What's a Dremel?
    18 Apr 2006
    I must have sent hundreds of parcels all over the world with parcel2go, tried others[when the prices are right] but can't see any reason not to stick with parcel2go.
    The online chat works well to solve any issues, if you want to mail or phone them, get their office number. Rather than a number they put up for contact, it's easy enough to find the numbers if you look and your enquiry gets dealt with straight away.
    Only couriers I will not use is parcelfarce and intercity, parcelfarce have lost a few parcels and seemed pretty unconcerned about it! When Intercity deliver to me I think I have always had to go and collect the parcerl from their depot.
  19. samkiller42
    25 Apr 2006
    From Parcel2go's Facebook page:
    https://www.facebook.com/parcel2go?sk=wall&filter=2
    They keep posting different codes, with different discount amounts.
    Sam
  20. bulldogjeff
    2 Mar 2010
    Thanks for all the replies lads. I'll have a look at all the options, will be posting on Monday so there's no mad rush. I can have a good old gander through all of the over the week end.
