Windows Partitioning a hard drive.
Discussion in 'Software' started by wufer, 24 Jan 2014.
  1. wufer
    wufer What's a Dremel?
    18 Nov 2011
    If i put a 70gb partition on a new hd, to fit windows7 into, what do i do with the unallocated part of the hard drive that is left.
    Cheers.
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Make it into an extra partition and use it for storage.
  3. itrush07
    itrush07 Minimodder
    28 Nov 2007
    I usually use it for backup purposes..
  4. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    I would personally use the extra partition for data so that if Windows does mess up you can re-install it without losing any data.
    Personal preference here but a backup to me should always be on a different hard drive as if your backing up to the same hard drive and the drive fails you lose your original copy of your data and the backup copy of your data
