Cases Parvum case: It has arrived.
Discussion in 'Hardware' started by Kronos, 19 Jun 2014.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    Move the images to my project log.
    The last two images show the PCI slots of which I needed 5 as I have Gigabyte board. Obviously this impacted on the sizes of the rest of the parts. Even in its flat state it looks good.
    There is a large bag of bits and no sign of fitting instructions. Those of you that have put one of these cases together is it pretty straight forward or are there instructions somewhere?
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Shouldn't be any different to the standard version. I'd compare images on the net to your case, lay out the components and get a clear image in your head of what goes where! Each panel looks distinctive so it shouldn't be too hard.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have not put a standard one together either. The panels are not the issue bar one bit which I cannot figure out where it goes, but it might become obvious as I progress. But I have 5 bags of different sized screws which I will have a specific position.
    Might have a count, later, of the various screws see if that helps working out which size goes where.
  4. Arboreal
    21 Jan 2011
    That looks nice! Blue and white is a nice combo.
    Great that Parvum can make a custom version for your 5 slot needs.
    Good luck with the assembly, I will be watching with interest.
    I have an ITX on order...how long did yours take to arrive?
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    To be honest not very long. Just had a look at when I paid for the case and that was the 4th June so about a fortnight. Which was fine.
  6. Arboreal
    21 Jan 2011
    Thanks, that's good to know. A fortnight for a hand made custom case is pretty good overall.
    Enjoy your build:)
  7. Arboreal
    21 Jan 2011
    Thanks again for the moral support, UPS have just arrived with a lovely flat parcel from the Parvum works.
    I asked for a custom 120mm front fan grille, and it looks amazing.
    Watch out for my build thread... Good luck with yours, it looks great so far.
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    Will do.
    I think the fun begins in trying to figure out which particular size screw fits where. I have sought advice from Justin at the works and Parge here who has done a build.
