Case Mod - In Progress Parvum Extreme MbK "Final Pics"
Discussion in 'Project Logs' started by kier, 20 Feb 2013.
  1. kier
    kier -----------------
    1 Mar 2011
    Parvum Extreme MbK
    Sponsored by:
    Hi fellow casemodders, Kier is back...again ;)
    This time I will start with a great new acrylic case
    Probably you have seen it allready in the buildlogs from L3p and K.3nny, the new Parvum systems S1.0
    The case is individually cut and hand assembled, various colors and custom modifications possible
    When unpacking I noticed the very good quality acrylic (5mm high quality acrylic) ... very hard material to work with, but not impossible, more on this later. The layout is also beautifully engineered.
    The case is available from mid-March @ Highflow Parvum Systems S1.0 White
    And @ http://www.overclockers.co.uk/showproduct.php?prodid=CA-000-PS
    How it all started:
    After missing the postman two times it finally happened. A BIG package:
    Very well packed
    Hmm 2??? yes 2 ;) Want to build something extreme.
    My kid really would like to know what it contains and whether it is for him .... unfortunately for him, these are for me :)
    Little picture with it from the two cases stacked.
    And a warning just in case ...
    A nice thank you letter from the Parvum family
    The black and white case with the following specifications:
    - Materials: Acrylic
    - Colours: Black/White
    - Dimensions (WxHxD): 275 x 305 x 420mm
    - Maximum CPU Cooler Height: 152mm
    - Motherboard Sizes: mATX
    - 3.5" Drive Bays: 2
    - 2.5" Drive Bays: 4
    - Cooling Front: 2 x 120mm
    - Cooling Rear: 3 x 80mm
    - Cooling Top: 2 x 120mm
    - PCI Slots: x 4
    4x PCI slots
    PSU opening
    Air outlet for the PSU
    Front fanholes
    And more 80mm fanholes at the back
    The mATX mobo tray, a hand bent acrylic mid-wall. Provides both case strength and the cable management
    With openings for the cables and possibly tubes
    The second case is slightly different internally and externally then the first original. Because I'm planning some fun stuff with this :)
    However, both with window
    Front is the same
    Furthermore the second case is empty, because I need only 1 hardware section. It is also slightly different at the back. 2x 120mm fanholes in the middle
    Also there were some nice extras in the package like:
    Case feets
    Some beautiful 240mm radgrills.
    And a 160mm radgrill.
    I also asked for some extra rest material for various purposes.
    Extra mounting stuff.
    Some last shots of the cases together
    To be continued ;)
    atc95 likes this.
  2. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    :D Will follow I love these cases!
  3. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    Every one is doing Parvum. Cool to follow how different those cases will be. will be following this one.
  4. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    kier + Parvum = awesomeness :D
    I'll definately be following this one!
  5. Da Vinci
    Da Vinci What's a Dremel?
    17 Feb 2013
    I'm new to this site, but have been following your work Kier. Looking forward to see what your skills can do with this rather tasty case......
  6. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    These cases seem to show up more and more. I'm really starting to love these cases! Keep 'em coming!
  7. kier
    1 Mar 2011
    Update
    Sponsored by:
    Thanks for the comments... and now modding time
    The idea is to stack everything. The bottom with the hardware, then the radiators and on top the reservoirs
    So Rads + fans on the original part of the Parvum
    To reinforce the lower part a bit i've placed some aluminum strips. Just to be sure
    Used the existing cubes to mount the next layer.
    On each corner
    Cut some side panels to the right size and an opening for the fans
    Like this
    And cut two pieces black and white. Black has the same same shape as the original front below.
    In this there will come an Asus ROG logo
    Placed the radiators. Still need to make brackets for these
    Also placed the fans
    Looks good allready I think
    ROG logo will be added later
    For the back I have cut 2 panels with fanholes to the right size
    And placed it
    Testing the fans and gives me a nice shot ;)
    And we continue with the next layer
    These will be all around with windows except the back. It will be the same height as the radiator layer.
  8. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    looking awsome kier !
  9. kier
    1 Mar 2011
  10. ziza
    ziza What's a Dremel?
    21 Dec 2010
    WOW the case is really amazing.
    Again another excellent build.
    regards,
    ziza
  11. KoSoVaR^
    19 Dec 2010
    awsome :D, looks like you are building original made pedestals for the case :p
  12. kier
    1 Mar 2011
    Update
    Sponsored by:
    So my modding friends time to end this Easter weekend with a big update.
    Asus also joined the party for this build. And they have send me a great motherboard.
    Btw. I have expanded my photo gear so the pictures will look like a bit different than normal :)
    The Asus Maximus V Gene
    The accessoreis:
    And the beautifull motherboard
    •LGA1155 socket for 3rd generation Intel® Core™ processor-based platform and 2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors
    •Intel® Z77 Express Chipset
    •SupremeFX III - Supreme Sound
    •GameFirst / Intel Gb LAN – Frag Without Lag
    •mPCIe Combo – Give Your PC A Power Up!
    •NIVIDIA® SLI™ / AMD CrossFireX™ Technology Support
    •LucidLogix Virtu MVP - Up to 60% Hybrid Graphics Boost
    Thanks Sven ;)
    Also placed the EKWB EK-FC7870 onto the GPU's.
    Placed the nice FC7870 backplates
    Time for some modding. Om top of the Parvum I placed the resevoirs, with here and there some acrylic tubes
    The outlets
    The inlets and one of the fill ports
    Everything straight
    And a total shot
    Placed top and mobo
    Installed the EK-Supremacy. Did some brainstorming for the tubes
    CPU outlet to the GPU inlet
    Then go right
    Placed the pump about as posted on the HDD cage, more about this later
    To hide the HDD/ SSD I have cut some acrylic. Also filed and polished
    Glued together with ACRIFIX
    Just a few more.
    Placed the pump onto the last plate.
    This week I will receive the last panels for the top after this it's time to do some last things
    sleeving and connect all the tubes.
    Grtz.
  13. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Looks great,mate. Really nice and good work. Thumbs up! :)
  14. imersa
    imersa Parvum Princess
    9 Apr 2009
    Getting better every update! :D
  15. AverageNinja
    6 Aug 2012
    I like especially those fans!
    Are those phobyas?
    Also, really nice system, I like it!
    Subbed!
  16. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Loving the hard drive covering system man really gives a nice flow to the internals
  17. elAwesome
    1 Nov 2012
    I think this is one of my favorite builds I've seen so far. Outstanding!
  18. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Jeesus effin' christ kier! How many can you do at once in a row before you blow up your dremel?! :lol: :dremel:
    Havent even a chance to read the log yet but I have faith in your skills!
  19. kier
    1 Mar 2011
    Thanks :thumb:
    Love the case mate :rock:
    Thank you....No, they are NorthQ fans
    Thanks Nate :thumb:
    Again one of your favorites? ;) :D
    Lol, i have more then one Dremel :clap::dremel:
  20. Inches
    Inches What's a Dremel?
    19 Jan 2013
    KIER!!
    This is ridiculous.. I was just talking to a guy about the ALX and now this.. My goodness!?!?
    You probably have a backlog of companies just begging you to build something with their parts!!
    If only I had the time... :(
