Case Mod - Complete PARVUM JAWS *Updated
Discussion in 'Project Logs' started by Goofy Flow, 11 Oct 2016.
  1. Goofy Flow
    Goofy Flow What's a Dremel?
    9 Oct 2016
    I'm so excited to start a new build with the support of awesome guys from Parvum Systems which I'd like to thank for their work and for their willingness, what else brand in the world is so attentive to own customer? Not many I would say!
    This build is dedicated at one of the best films of all time, at least for me but I hope for you too, and one of the most famous Spielberg's movie, Jaws.
    The basic idea is inspired by one of my favorite build ever, called "Xenomorph" of Akira749, namely to recreate the features of a creature / monster / villain (the xenomorph in the akira's build and the shark in mine) and the "atmospheres" of the movie.
    First, I explained to Justin my ideas for the subject and for the most suitable color scheme, then he designed the render in my place.
    The case is rich of details, the shark bites are just what I wanted, they give a very personalized look to the entire case, the movie logo is the cherry on the cake.
    Sponsor & Support
    Solid Strands
    Parvum Systems
    ColdZero
    Mayhems
    Main Components
    Case - Parvum Systems S2.5 (Custom Themed)
    CPU - Intel i7-7700K
    Motherboard - Maximus VIII GENE
    Memory - 32GB HyperX Savage DDR4 2800MHz
    GPU - Asus Strix 1080 Ti
    SSD - Crucial MX500 1000GB
    PSU - EVGA G3 750W Supernova
    Watercooling Components
    CPU Block - EK-Supremacy EVO - Full Nickel
    GPU Block - EK-FC1080 GTX Ti Strix - Acetal+Nickel
    Radiators - Alphacool NexXxoS ST30 Full Copper XFlow 240mm - Alphacool NexXxoS XT45 Full Copper 240mm
    Pump/Res - EK-XRES 140 DDC 3.2 PWM Elite (incl.pump)
    Fittings - EK all Nickel
    Tubing - EK-HD PETG Tube 10/12mm / Copper nickel-plated tube OD 12mm
    Coolant - Mayhems Dye Blu / Mayhems Ocean Blu
    Miscellaneous
    Fans - 4 x EK-Vardar EVO RGB 120mm
    Cables - MDCP-X Blue-Carbon Custom Sleeved Cables
  2. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    This looks badass!!
    And yes the guys over @ Parvum Systems are AWSOME!!
  3. Goofy Flow
    9 Oct 2016
    edit
  4. Goofy Flow
    9 Oct 2016
    edit
  5. Goofy Flow
    9 Oct 2016
    edit
  6. storm-83
    storm-83 Minimodder
    7 Nov 2014
    nice colors on the panels
    looking forward to seeing some hardware in this thing
    * edit *
    i would have suspected that jaws was going to gobble the reservoir, but (sadly) i see a transparent sheet there...
  7. Vault-Tec
    30 Aug 2015
    We're gonna need a bigger case :D
  8. Goofy Flow
    9 Oct 2016
    Thank you :thumb:
    What do you mean "was going to gobble the reservoir"? :confused:
  9. Goofy Flow
    9 Oct 2016
    :D
  10. storm-83
    storm-83 Minimodder
    7 Nov 2014
    In the movie, they blow up the shark by making it bite a gas canister. would be cool if the canister was the reservoir!
  11. Goofy Flow
    9 Oct 2016
    edit
  12. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Nice design concept
  13. Goofy Flow
    9 Oct 2016
    Thanks :thumb:
  14. Goofy Flow
    9 Oct 2016
    Now is time to choose the color pattern for the sleeving, which must fits the theme and "dark environment" like abyss or deep water, black and dark blue for "recreate" the deep water environment, grey to match the logo and shark skin.
    This is what I choose at the moment, suggestion are welcome (pay no attention at the red logos of the mobo) ;)
  15. Goofy Flow
    9 Oct 2016
    Coming soon from Coldzero, they are very nice guys :)
  16. Goofy Flow
    9 Oct 2016
    Finally I came back with the build, after the loss of Ice Modz sponsor's, which take off from the sleeving scenario, but fortunately I get a new sponsor from the guy of Purple Banana, Julian, which is new in the sleeving scenario, but he provide the best quality of MDPC-X sleeving [​IMG]
    In the mean time, I also re-design the case a bit with a new panels (coming soon from Parvum house) and get all the hardware.
    This is some pics of the hardware and sleeving, I improve a bit the quality but I can do more [​IMG]
    More pics of the hardware soon [​IMG]
    HPC likes this.
  17. Goofy Flow
    9 Oct 2016
    Tons of pics of cables and fans to test the new white backdrop, pretty happy with this.
    I also painted the fans in blue, more or less the same blue of MDPC Grand-Bleu sleeve, I really like this fans and I will sleeving the cables with black MDPC sleeve.​
  18. Goofy Flow
    9 Oct 2016
  19. Goofy Flow
    9 Oct 2016
    Little update with motherboard heatsinks and ssd cover painted in blue ... I also sleeve all the fans with black MDPC sleeve.
    I want this build even more detailed, so I will create some custom vinyl decals for the heatsink, fans and case as well with Silhouette Portrait.
  20. warboy
    warboy Insane modder
    24 Nov 2011
    Amazing work bro! I like how you did the case
