I am finally getting there with my white prototype parvum ITX case and want to replace the standard black screws with stainless ones. What size are they? And what are the 2 lengths? (I can never remember whether you have to include the head...) Thanks guys
I'll take Kronos' word on the size but no, you never include the head when measuring screw (or bolt) lengths - though certainly the type of head matters especially if needing a flat or countersunk head.
Thanks guys, engineering training continues. I have emailed Parvum in the past, and know that they are habitually busy - please to know they're being successful. Glenn, that's ideal, I'll count up and get some 6 and 10mm ordered in stainless from my usual supplier. BTW have you put any dust filters on you Parvum? I have a large area in the top for the graphics card to intake, and it is a perfect dust trap.
Yes I have and for the price of these cases better provision for dust filters could be included. That is a large gap at the top of the PCI bracket. If you install a 120mm rad then putting a filter or fan over the other fan slot is problematic. I have one held in place with double sided tape. Not ideal but not much else I could do.
Thanks Glenn, I'm just getting going with my Parvum, but have also been working up an alternative case mod to house the same kit. I have wanted to do a design of my own, it's taken longer to sort than hoped. Love the Parvum clean cuts and design, but a couple of little things niggle like dust and the PCI bracket in mine seems a bit out (nothing disasterous).
