Scratch Build – In Progress Parvum Systems Project Magnus - 19th April - i51 LAN
Discussion in 'Project Logs' started by imersa, 19 Sep 2013.
Which coolant for Magnus?
  1. Clear : Clear
    7 vote(s)
    13.7%
  2. Pastel White : Oil Black
    34 vote(s)
    66.7%
  3. Translucent Red : Clear
    10 vote(s)
    19.6%
  1. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Quick pop in - Ah man, those RAD's, fans and the braiding, not forgetting the the tubing and fitting work.
    Keep it up, builds really coming along bud!
  2. imersa
    imersa Parvum Princess
    9 Apr 2009
    So didn't actually even test it myself until this morning. Hooked the 4 fans up to a controller in the roof and ran at max speeds. These are only 10,000 fans. But my results are they couldn't be quieter? Like probably the quietest 120mm fans I've ever used.... I'm not sure if this means I'm except from the problem but it seems that way. I'm thinking it could be to do with the AX series rads? Not so much the fin spacing perhaps but more than external housing giving you a fair bit more space between the fan blades and the fins? I'm not sure if this is effecting performance or if they are even pulling much air but there are certainly no audible issues what so ever.
    I did read a bunch of people commenting on threads saying they aren't having a single issue so I'm pretty lost here I guess...
    Haha look guys I'll keep a crate of red stripe in the car and leave it unlocked ;D
    Honestly mate. Super stoked for LAN and super stoked on the fans. Really great and I'm actually not seeing this fan thing as a problem at the moment at least.
    Thanks for popping in mate :D going to try install some more radiators today! woop!
  3. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    Red Stripe? Red Stripe, c'mon man, I don't drink lager ;)
  4. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Great.........more for me then :naughty:
  5. shrop
    22 Jul 2011
    Hahah you are welcome to it man! :D
  6. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Going by what the fan guys on OCN are saying,its a noise thing and it loses speed,it could well be that the AX design gets around this.
    Either way,if they are working fine then its not an issue.
    You ran them on the rads i take it?
    http://www.overclock.net/t/1289723/...ionic-loop-propeller-fans/80_20#post_18322825
  7. imersa
    9 Apr 2009
    Yeah tested on the rads in the roof. Literally dead silent and I honestly think it is due to the AX design. I'll test on a traditional radiator and report back. I'd like to hope in a way they make a bunch of noise so I can at least be sure they are performing well on the AX.
    I'm a happy camper if it's as easy and not making any changes :D
  8. GeorgeStorm
    16 Dec 2008
    Those fans look lovely, nice work on the sleeving.
  9. imersa
    9 Apr 2009
    Need to make sure we all get out of the place for a few hours and smash a good curry or something this LAN. Always get the LAN lurgy spending 5 days in that place haha.
    Thank you George! Pexon is to take that compliment ^^ :D
  10. shrop
    22 Jul 2011
    No decent curry places around here though man, there are a few nice places in Shrewsbury however, could get a taxi down there
  11. B NEGATIVE
    8 Aug 2011
    Coolmiester knows a good place 10 mins drive away,its like the guys front room.
    Good curry too
  12. imersa
    9 Apr 2009
    Well then it's sorted. for anyone not interested in our dinner plans there will be a nice update tomorrow !
  13. coolmiester
    31 Dec 2002
    For sure Justin..........i can’t exactly remember where it was but been there a few times and it was the taxi drivers nephews uncles half brother that owned the place so we’re sorted :thumb:
  14. shrop
    22 Jul 2011
    They are all related ;)
  15. imersa
    9 Apr 2009
    MORE RADS MORE FANS
    Sponsors/Support:
    HOLD UP...! ITS TIME AGAIN!!!
    Going straight in with some adjustments to the white bottom chamber. Cable management was impossible to be clear when we did the drawing for Magnus as we really had no idea what we even going into the build. In turn however this gives a really nice and easy 'hands on' way to planwhat changes we want to make.
    The old:
    The NEW:
    As with all cases Magnus is fully modular. It makes making changes like these a lot less stressful. Unscrew and slide the new panel in place:
    New panel in and with the addition of two new cubes (you'll see what these are for shortly) and better cable holes:
    More changes and this time on the bottom black panel. By using the technical drawing on the XSPC website we managed achieve this first time:
    Time to install more of these beautiful fans:
    A mirror now of the top chamber connections. Connecting the two rads together with acrylic tube:
    Two more new cubes. These will correspond to the two I mentioned earlier:
    This little frosted guy will be doing the work between the four cubes:
    Installed:
    Entire panel installed in the bottom of the case now:
    The purpose of the frosted panel will become clear now. It basically acts much like the mid wall does in the body of the case and provides much needed extra strength. We did this as the rads are heavy even before they get filled with coolant. If you are wondering why frosted and not black. Frosted acrylic is in much less demand at work & this part of the case wont be visible:
    Now you can see what the new cable management holes are for. All falling into place well:
    Last for today we install the fifth and final 240mm radiator into the system:
    The clearance and fit we are very happy with. Had people mention vibration issues from the fans/rads touching panels like this but had no issues in previous builds and no sound problems upon test run:
    So we did get a bit more done on the build but no more time for Photoshop today so will end it here.
    Love it? Hate it? Ideas? or even just want to show some love; VERY WELCOME!
    THANK YOU SO MUCH FOR READING!!
  16. Noob?
    18 Oct 2009
    WTH man!
    Let me breath, all this kit, its sooooooooo lovely and the builds coming along so well.
    I need to sit down.
  17. bulldogjeff
    2 Mar 2010
    Oh dear, this is just to good, lovely build.
  18. imersa
    9 Apr 2009
    Thank you both! Had a great short weekend of rest and looking forward to making some solid progress this week :)
  19. el2k
    el2k Modder
    18 Jan 2010
    This is whack mate!
  20. Ianovski
    Ianovski Rawr!
    10 Mar 2011
    The way you mounted those rads.. I love it! Looking very sweet, this build!
