Scratch Build – In Progress Parvum Systems Project Magnus - 19th April - i51 LAN
Discussion in 'Project Logs' started by imersa, 19 Sep 2013.
Which coolant for Magnus?
  1. Clear : Clear
    7 vote(s)
    13.7%
  2. Pastel White : Oil Black
    34 vote(s)
    66.7%
  3. Translucent Red : Clear
    10 vote(s)
    19.6%
  1. imersa
    imersa Parvum Princess
    9 Apr 2009
    Cable Management
    Sponsors/Support:
    HOLD UP, HOLD MY PHONE!!
    Won't be able to annotate AS much this time. Pretty busy to say the least.
    First up cutting a new cable management piece. Notice the V-bit 45° cut. This is vital to get the piece to actually fit.
    Measure up:
    Apply heat:
    And bend:
    Repeat to complete:
    You can see now how the 45° was necessary:
    Did another couple of tubes for the rear rad:
    Installed the fans on the 360. Really cant get over how good these rads and fans are:
    A little look in the case internal... suppose it's a bit anticlimax now half the stuff has been taken out:
    Back to our old tricks. Really like physically marking stuff:
    Then do it all again but with holes:
    Installing the cables:
    That would be it for today.
    Thanks for checking in :)
  2. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    Looking good J keep up the good work!
  3. keenan
    keenan Minimodder
    12 Nov 2013
    This is awesome on an OCD level!! Love the cable management!!
  4. imersa
    9 Apr 2009
    Thanks guys. Will have an update with most of the loop connected tomorrow or Wednesday!
  5. imersa
    9 Apr 2009
    more tubing
    Sponsors/Support:
    Hi folks!
    Will let the photos talk. Managed to hook up the second GPU and the 240mm rad at the back. Basically 90% of the hard line work done now which means we can really start to speed things up here:
    Decided to use acrylic tube to connect GPUs as we've used a lot of it. Thought the XSPC connecting system may have looked out of place:
    Another pretty wild tubing run:
    Hello third GPU; nice to see you:
    Also connected up the back 240mm rad:
    Will be a fuller update soon. Sorry for the small ones :)
  6. kier
    kier -----------------
    1 Mar 2011
    Some crazy tubing... love it!!!
  7. imersa
    9 Apr 2009
    Thanks Kier. Looking forward to filling it and making a video :D Updates soon!!
  8. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    No pressure mate but you do know i50 is THIS week :worried:
  9. imersa
    9 Apr 2009
    Don't :(
    At the moment parts required to finish it are still not here. I hope they show up with the mid day post today... pretty annoying. The next day delivery was supposed to be here Friday.
  10. jinq-sea
    15 Oct 2012
    This is looking fully awesome... Fingers crossed those parts arrive with the post...
  11. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    J, I need moar! MOAR!
  12. imersa
    9 Apr 2009
    Magnus will not be coming to the ball. The company providing the O Rings decided to lie last week and say they would be with me the following day. Still not with us and without them we'd have a very leaky rig.
    It's an annoying set back but ultimately not so much of a bad thing. It would have meant rushing the rig and thus not allowing us to actually give you guys much if a project. Considering we have some of the best parts of the build yet to come id rather wait.
    It also means by friend can come help film the loop filling so worth holding out.
    As for the project log ill have a baby update posted Friday night. Made a cool pump bracket and tested one of the custom milled parts!
  13. coolmiester
    31 Dec 2002
    Damn shame mate as i was really looking forward to seeing it but good call as its pointless trying to rush a build of this high quality.
    Fingers crossed i see it at i51 :hehe:
  14. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Ok, ok, so I think it looks a wee bit crazy with those long hard acrylic tubes sitting there across almost all of the insides, blocking the view of that gorgeous hardware, but I BET it'll look much, much sweeter once that loop has been filled up. Yo, O-ring guys! Get your act together! ;)
  15. parkwaydrive2013
    parkwaydrive2013 What's a Dremel?
    18 Nov 2013
    This is such a stunning build guys love the tubing aswell. keep up the good work and ill see you at i50. your builds are truly outstanding :)
  16. imersa
    9 Apr 2009
    Yeah it sure is crazy... someone who saw it in person said the tubing looks a bit like spider man spraying something out of his... wrist! ;D
    O-Ring update!!! 'We are pleased to let you know your order is on its way to.....'
    We are in business. Look forward to updating you all as and when.
    See you tomorrow mate. Look forward to you seeing the older builds in person!
  17. imersa
    9 Apr 2009
    Milling custom parts & more braid
    Sponsors/Support:
    Back with another update:
    First up we draw... powered by Monster Energy!
    A little while later the CNC can start the job. 5mm frosted clear acrylic. Tooling for this job 3mm single flute and 2.5mm single:
    Understand this is a test for what will next be cut in the 25mm thick block I showed some updates ago:
    At the time of photography the O Rings had not turned up. However they have now and I can let you know we are fitting no problems. We will cut the 25mm next.
    Time to smarten up the D5's; XSPC pump tops and MDPC braid:
    Next a small make over for the fans. Grabbed some little fan stickers from Nate over at E22. Nate has helped out as and when he can and was a great guy when we met him. Sadly we don't get to see enough of him. He has also sent us a few other useful things that finish this build nicely:
    Before:
    After:
    Simple indeed but so necessary.
    Braided the molex to mini-sata. Wasn't sure if there was a better option for this but needed something to power the slot loader so these seemed sufficient:
    Next task was to make some kind of mount for both the bumps. A lot of people ask why we don't use other materials such as aluminum wood etc. For the most part anything we do cut we wait and cut while we are already cutting that colour of acrylic. For example we cut these frosted clear parts when we had to cut frosted accents for a customers case. It's realistically the most feasible way of getting a project log done while not interfering with to much of our workload.
    We need something to sit on please:
    You can sit on me!?
    OK thanks:
    Some little fix ups on the sata cables:
    So that's all for the update this time around. Lot of small bits but they all have to be done so please stick with us!
    I will leave you with a couple of photos from the Multiplay Insomnia i50 LAN event. Any questions please ask:
    Thanks for reading. Please ask questions and leave your opinions!
  18. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looks great guys, also looks like an awesome Lan! can see you had a nice corner going on ;)
  19. imersa
    9 Apr 2009
    Thanks Nate, was a shame you didn't make it to iSeries! Did you hear the location is now closer for us? I imagine it would shave an hour off for you. Yeah the Parvum corner is always the party spot :D
  20. kingpraun
    kingpraun What's a Dremel?
    27 Aug 2013
    Getting there mate! Hope it gets to i51 in one piece. :D
