Case Mod - In Progress ⭐ Parvum-Systems R1.0 ATX AORUS build Worklog
Discussion in 'Project Logs' started by CustomRigs, 28 Jun 2018.
  1. CustomRigs
    CustomRigs CallMeCleaner
    8 Dec 2017
    Worklog to my actually Build "Parvum-Systems R1.0 ATX AORUS"
    Thanks to all my supporters that they trust in me and help alot to made this build become real
    AORUS WATERCOOL TEAM-GROUP INTER-TECH Arcturos-Solutions
    PARVUM SYSTEMS
    NOISEBLOCKER
    Parvum Systems R1.0 ATX AORUS Themed Green and Orange
    Hardwarespecs:
    AMD RYZEN 2600X with Heatkiller IV CPU Kühler
    AORUS X470 Gaming 7 Wifi
    16GB quad Kit Team-Group T-FORCE DELTA RGB 4x4GB 3000MHz
    2x GTX 1080 Founders SLI with Heatkiller IV GPU Block
    1x 256GB SAMSUNG M.2 NVME SSD
    2x 256GB Crucial MX 100 SSD (altbestand)
    Inter-Tech SAMA FORZA 1200W PSU
    2x Heatkillertube with DDC Pumps
    2x 360mm Magicool Rads
    11x Noiseblocker BL12-PS ELOOP Black
    BARROW 16mm Chrom Hardtube fittings
    Planed: Distributionplate laying on the midplate, Acrylic Terminals for the Heatkiller GPU blocks, Custom SLI Bridge with RGB lightning, full sleeved psu cables
    One Draft and some pictures from the case
    Renderings from Parvum
    Finished Case
    Fitting with hardware for measurements
    _Prometheus_ likes this.
  2. CustomRigs
    8 Dec 2017
    Well :) i designed an acrylterminal for the heatkillerblocks. The 3d modells actually given to my cnc milling guy and not that easy to mill because it is a four side processing.
  3. CustomRigs
    8 Dec 2017
    Here is my finished distributionplate, also with polished aluminium cover to match to the heatkiller gpu blocks :D
    Distriplate_FINAL_FINAL_1.jpg Distriplate_FINAL_FINAL_2.jpg Distriplate_FINAL_FINAL_3.jpg Distriplate_FINAL_FINAL_4.jpg Distriplate_FINAL_FINAL_v1_2018-Jun-29_06-05-59AM-000_CustomizedView13667147240_jpg.jpg
  4. CustomRigs
    8 Dec 2017
    Exchanged the struts on the HK tubes and added lightning. also does the 3d modell for sli bridge cover [​IMG]
  5. CustomRigs
    8 Dec 2017
    okay [​IMG] all parts have lighting but the heatkiller IV not !
    designed a lightingmodule today by my self [​IMG] first prototype gets 3d printed. final module gets cnc milled from aluminium. build the HK IV in fusion 360 today [​IMG] was fun and the first more complex 3d modell for me
  6. CustomRigs
    8 Dec 2017
  7. CustomRigs
    8 Dec 2017
    How a Heatkiller IV CPU cooler looks with lighting ? soldered the leds today. The lightingmodul which covers the led strips gets printed tomorrow! You can see a render in the pictures. I did a last new rev. of the module. Screwless design. Easy to mount.
  8. CustomRigs
    8 Dec 2017
    Im waiting for the cnc parts and used the time:) to create the whole build as a 3D model :D it is not that detailed but you can imagine how it looks when the build is finished. These are the last rendered pictures ... next log comes with real pics ;)
  9. CustomRigs
    8 Dec 2017
    first rev of my lightingmodul for the Heatkiller IV CPU Cooler is done [​IMG]have to do some changes on the next rev and also try to integrate a plug in the module [​IMG]
  10. CustomRigs
    8 Dec 2017
    Ive done some prework on the basement and had to spin one rad around. Because off using two diffrent loops it was necessary ... theres not much space but i put the two drain ports in. Using 16mm softtubes for the basement. I think if i use 360 slim rads it would be much easier but i dont have 360 slim rads xD ... when the distriplate arrives i just had to connect the fittings and shorten the tubes :)
  11. CustomRigs
    8 Dec 2017
    the distriplate also arrived but i ahve to do the treading the next days :)
  12. CustomRigs
    8 Dec 2017
    some more pictures :D
    Goatee likes this.
  13. RooiDuiwel
    RooiDuiwel What's a Dremel?
    20 Sep 2009
    those are some damn fine custom parts
    keep it up
    looking forward to what will be made next
    CustomRigs likes this.
  14. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Nooooooooooo! It ended, I started the thread thinking... urghhh, the scene has become so dull, why does none of this excite me anymore... *all the while scrolling down* then I picked up on the effort you're putting into this, the 3D work and fresh loop design.. the LEDs you'd added to res(s), the cpu! wicked! I'm in! Top work buddy! I'm not a huge fan of the colors you picked for the R1.0 and I'm absolutely over the RGB fad but I do think this is gonna be special. I've always got a soft spot for a Parvum build. Please do an awesome job with your cables! :)
    Subbed
    J.
  15. CustomRigs
    8 Dec 2017
    thanks alot :) the build didnt get RGB lighting ... but it can :D Im using just white lighting ;)
  16. CustomRigs
    8 Dec 2017
    Did some testing to the lighting of the watercooling components :) Mainboard is not connected because the psu gets full sleeves at this moment ;) distriplate is not on the pictures :D but it will also have a lighting module.
    On this pictures here you also can see my final Heatkiller IV cpu cooler lighting module :)
    My custom acryl terminals on the Heatkiller GPU blocks look awesome !
    kim, MODZERO and jenners like this.
  17. CustomRigs
    8 Dec 2017
  18. CustomRigs
    8 Dec 2017
    Today i did the leakcheck to the distriplate :) all is fine :D
    The distriplate is also on its place and i can begin with the tubing :)
  19. CustomRigs
    8 Dec 2017
    Tubing is in place :) waiting for the PSU
  20. CustomRigs
    8 Dec 2017
    mounted the sli bridge cover today :)
