Modding Passing off my design to the modding public
Discussion in 'Modding' started by Guest-16, 11 Jun 2005.
  1. Guest-16
    Guest-16 Guest
    That's obviously just in pencil, but im gonna get a brush and paint it metalic blue shortly. I just want a variety of opinions about it - too big/ too small curves? About the right amount? Look "uniform" ish? I was planning on covering the whole side but the little bit looks better imo.
    As for the actual design ive been doing it years - i generally cover the inside of folders with biro and tipex (ill get a pic of my GCSE history folder later), all the lines flow into points, typically the point are a different colour to the interpoint connections but i dont think i can pull that off with paint.
  2. ZuNe
    ZuNe What's a Dremel?
    2 Jun 2005
    I like the design!
    You should see the inside of my folders.lol :rock:
    Metallic blue would look really nice with that black ;)
    :thumb:
  3. sirbogey
    sirbogey What's a Dremel?
    7 Jun 2005
    nice one, had something similar once on my Jackson guitar in orange slowly converting into yellow; resembled a fire. Had it done through an artist though. Looked awesome! show us the final version!!
  4. Guest-16
    Guest-16 Guest
    First coat done, should look better after 2 but my hands seriously ache after such doing such detail with a brush rather than a biro.
    You can see the blue fan-grills in the background that will complement them.
  5. Arkuden
    Arkuden mow?
    9 Jul 2004
    that turned out quite nicely. I dont quite have the artistic ability to draw something out like that but i dont mind doing the the tracing with a brush and paint if i have something to follow. Do i see a cube case in that pic? if so i likey any; info on it?
  6. Guest-16
    Guest-16 Guest
    It's just a standard YY cube ive *******ised with a 120mm in the roof and extra 120mm in the front and it's got about 4 layers of black spray on it as well as complete akasa carpetting inside.
    Once i had the pencil down i could brush it pretty easily, the brush strokes add a nice effect compared to spray.
  7. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    looks schweet, but why is the side blowhole a square, and the top one a circle? the circle looks way better imho.
    or maybe the fan grill will cover it and this post is useless
  8. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    Looks cool; like the drapery used in heraldic design rather than flamejob paint.
    I like it.
  9. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    That looks mint man, those colours go real well together, and the design is awesome, well done :D Put up some pics of it with the grills in there too :B
  10. Guest-16
    Guest-16 Guest
    because the 92mm was already there. YY in their infinate genius decided to make it square and it's too big to make a proper circle out of so i left it. The fan grill hides that though :)
    Thanks for the nice comments peeps :D
  11. Guest-16
    Guest-16 Guest
    The right side match has been fixed since the pics.
  12. Zekey
    Zekey What's a Dremel?
    10 May 2005
    Wow! That looks really great! I absolutely love that case, too.
  13. adam197
    adam197 What's a Dremel?
    22 Feb 2005
    That is very nice. Nice choice of colour.
  14. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    nice idea I am thinking white on black for my pc with the same idea
  15. thydzik
    thydzik What's a Dremel?
    19 May 2004
    very nice
  16. Hiren
    Hiren mind control Moderator
    15 May 2002
    Nice job Richard. Simple but effective.
