Scratch Build – In Progress Passive NUC "Bum Muffin" -There, I named it. May 15-final pics on page 4
Discussion in 'Project Logs' started by Cheapskate, 3 Feb 2014.
  1. Cheapskate
    13 May 2007
    Thanks, Guys. I named it now. -poorly.
    -Lighting has been an issue lately. Recently I picked up some cheesy LED yard lamps from a house I'm cleaning up. (****. I still have to dismantle the lobster tank.:() With the help of some PSU scrap, a switch from an old 486, and a power brick from one of those cordless phone sets that die after a year, I put together a something. I think I paid for the 3 resistors, and maybe the hot glue was a work write-off.
    -Here's the full ghetto ensemble. If a homeless person had a mill, this is what it would look like, just under a bridge.
    -I went with the EEL Ambience color scheme.:lol: The wire ties came from the cleanup job, and the heavy orange wire has been around since the '70s. It looks like I'm building an EMP cannon instead.
    -Maybe next time...
    -Wow. I can see, 'n stuff.
    -D'oh! The paper backing came loose at the last minute.
    -Here I'm milling out a pocket on the inside of the face. I think this will work better for getting light through the layers.
    -A sneak peek of the housing plan.
    -I mentioned earlier the chips are NOT the same height. There was a perfect layer of thermal goo on the main chip that made up for the discrepancy. I think I should try to do better. This may be part of why it runs hot.
    -The current generation probably doesn't know about these.:D This is a (dismantled) spark plug gapping kit. This set runs from .035" down to .0015", and are great for figuring out height discrepancies. I had totally forgotten about this one, and the humidity has taken it's toll.
    -Anyway, after a cleaning I worked out that only the .005" shim would fit in the gap.
    -More pickie, less chatty monkey!
    I put the fly cutter in the mill, and leveled both sink surfaces. Then I moved to the GPU sink and whittled it down .005".
    -Now I'm working on getting the heat sinks flat. Cripes! It's not easy to lap a heatsink the size of an ITX board! The sandpaper is only a little bigger. I'm a bit worried about losing the heat pipe integrity, so I'm checking it by pressing the flat area with a fingernail. If I make a dent, it's probably time to stop sanding. What you see here is an hour and a half of sanding at 240 grit. It started to get easier, and I realized it was because there wasn't any grit left on the paper.:lol:
  2. Cheapskate
    13 May 2007
    -I got a little playful with the switch design.
    -Fingerprinty. (Why, Yes spellcheck. I do know that's not a word.)
    -Like the Tooobular NUC, I have to flip the part to make a pocket for the button. Here I'm using a dremel bit to find the center.
    -Milled.
    -Hey! I found a use for one of those oscillating cutters. I used it to lop off some of the stuff on the inside of the HD plate.
    -Then I milled the stuff still sticking out nice and flat. I stuffed a rubber toilet shim in that hole in the front to silence the RINGING.
    -Later I milled one edge off. -WAIT. I milled it short? I milled it short! I must've had the sink turned 90 degrees when I drew the line. I'll come up with something.
    -Milling porn.:D I love milled powder coat.
    -The inside of the HD plate has a low spot that's getting in the way. It's easier to chop the plexi wall, so that's what I did.
    -But for now, it's Spring distraction season, and ghetto construction is in full bloom. Two aluminum pans and a stick?
    -No, It's tool rack 2.0.:D I made this to replace a '60-era plastic rack that is being crushed under some serious tool mass.
    -Next up is the one in the garage. It caved in the middle sometime this winter.
    -THEN I can expand the spare hammer rack.:lol:
    alfizzle likes this.
  3. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Why do you have so many hammers?
  4. Shirty
    18 Apr 1982
    A man can never have too many hammers. Or crowbars, according to my garage.
  5. Cheapskate
    13 May 2007
    Agreed. -That's just garage hammers, BTW. :lol:
    @Pranja - They are a bit like coat hangers. They just seem to multiply. Most of the wood ones are +50 years old.
  6. craig - toyoracer
    craig - toyoracer Member
    1 Mar 2011
    Might be more like Cheaps is a very organized Hoarder. :lol:
  7. Guest-16
    Guest-16 Guest
    He's real name is, Thor.
  8. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    For when it is hammer time :p
    As said you can never have to many hammers (only to few)
  9. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Or maibe he's a human-squid with a hammer in each tentacles
  10. Nexxo
    23 Oct 2001
    Aren't you the guy who turned the mill by hand during a power outage during a hurricane? You, sir, are a GOD amongst MODDERS. You are HARDCORE. I bow to your superior mod-fu, for it is strong.
    (And spark plug gapping kits! Great idea --just what I need for shimming cutting tools on the lathe.)
  11. kenco_uk
    28 Nov 2003
    I think the name is very distasteful - bum muffin. Even typing it makes me want to scrub my hands clean.
    It should be bum crumpet. Far better.
  12. Cheapskate
    13 May 2007
    :lol: -No one plays "hammer catch"?
    @Craig -No. I give to those in need of a hammer. I make sure to keep the ones that were inherited, though.
    @Bindi - You've seen the hammer I use for work, obviously.:lol:
    @Nexxo - That story gets a little more wilder every time it's re-told.
    @Kenco - Bum crumpet sounds more like something is going in rather than out... Ew...
  13. JD Design
    JD Design New Member
    13 Feb 2014
    : Jawdrop: very nice job
  14. Cheapskate
    13 May 2007
    Seems to work so far. Temps still not stable yet.
    -I guess I need a few updates still...
  15. Darkened
    Darkened New Member
    28 Feb 2004
    From naming your mods to the hobo-ness of your milling machine, these project logs are always a great fun to read :D
    Keep up the craziness :thumb:
    Darkened
  16. AlderonnX
    AlderonnX Member
    10 May 2012
    i'm sending you a hammer Cheaps ! hate to see a modder in need
  17. Egami
    Egami Why is the dremel on fire?
    27 Aug 2013
    From the emp cannon wire to the tool racks, you sir are magic. I don't know what it is with the modern hammers but they just don't have the same feel as the ancient wooden handled ones.
  18. Meelobee
    Meelobee New Member
    5 Nov 2003
    What...someone had to do it.. :D
  19. kenco_uk
    28 Nov 2003
    I think Meelobee hit the nail on the head there. Nothing like hammering a point home.
    cough
  20. Cheapskate
    13 May 2007
    Yeah, -never should have posted the hammers. :lol:
    @Darkened -Thanks:D Please keep doing what you do as well... Maybe not the long hiatus part.
    @AlderonnX -I broke my only useable axe and lost the head in garage chaos, but I'll pass on hammers.
    @Egami -Thanks.
    @Meelobee & Kenco - Please refer to line on of my post.:D
    If this keeps up I'll have to re-post the Arthurian-esque story of how I got my current hammer.
