A/V Passive speaker Amp
Discussion in 'Hardware' started by Lankius Maximus, 25 Oct 2016.
  1. Lankius Maximus
    Lankius Maximus Minimodder
    21 Aug 2009
    I have a couple of redundant speakers (Cambridge Audio Min21s) I would like to start using as PC speakers. I already have a DAC in the form of a Creative E5 so I am looking at getting hold of an AMP to power them. 2.0 is fine but something with a sub would be ideal.
    Does anybody have any experience with Chinese amps? They seem ideal but I know sometimes things appear to be too good to be true. These ones caught my eye in particular....
    https://www.amazon.co.uk/dp/B008Y7S198?psc=1
    https://www.amazon.co.uk/Q5-Coaxial-Optical-Digital-Amplifier/dp/B015ZHZG1K
    I know I will have to change the power supply as there appears to be a bit of a swerve regards UK regulation with them.
    My other choice is then a jump to the Pro-Ject Pre Amp
    https://www.amazon.co.uk/dp/B00AMZA2K6?psc=1
    Which gaurantees the build quality but with no Sub out and at quite a bit of a price difference.
    Any thoughts would be gratefully received from anyone with a bit of knowledge around this.
  2. asura
    asura jack of all trades
    22 Apr 2009
    I like NAD... overkill for your tiny speakers, but you can get a really decent quality stereo amp for sixty five spondiloonies if having a sub is a necessaty, buy a second one and take the monitor output from one as the input of the other, and bi-wire to your sub...
    ...did I mention I like NAD? Other options are available and I'm sure less monomaniacal people will chime in with advice.
  3. Lankius Maximus
    21 Aug 2009
  4. teacherboy
    teacherboy Part Carbon/Nylon/Bovine
    29 Jan 2012
    what about one of these
    Denon DM40 DAB/CD/USB receiver/amp
    Have one in my kitchen paired with Q acoustics 2010i speakers and its magnificent - at higher end of the price range but gives you more - inc 2 optical inputs (for chromecast music/tv/input from toslink)/rca inputs/sub out as well
  5. Lankius Maximus
    21 Aug 2009
    Not wishing to resurect a long dead thread but in order to conclude this one......
    I found a small British company called Amptastic, and went for their Mini 1 model,
    https://www.amptastic.com/
    As mentioned in my first post I was drawn to Chinese manufacturers such as Lepy and SMSL regards both price and the physical footprint.
    This came in at about the £100 mark and (with no disrespect to Chinese manufacturers) is put together over here and has a plug that doesn't spark when you connect it!
    Most importantly after a month of use it sounds superb even with my litle speakers. In fact Im going to upgrade the speakers to a set of Monitor Audio Bronze 1s as it sounds so good I genuinely enjoy listening to music from my PC with it (I just need a bit more base and Im not convinced I can attach a sub to it).
    Ive attached an image so you get an idea of scale.
    [​IMG][/URL]
    Great piece of audio kit.
