Graphics Passively Cooled X800XL
Discussion in 'Hardware' started by DrillSgt, 5 Jul 2005.
  1. DrillSgt
    DrillSgt What's a Dremel?
    15 Mar 2004
    Anyone heard or had any experience with these?
    I'm thinking specifiically about the Gigabyte Radeon RX800 XL 256Mb PCI-Express GV-RX80L256V, although I hear that more brands are bringing product to market.
    Linky
    What can I say, I want my cars loud and my PC's quiet.
  2. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    the heat has to go somewhere, so unless you have good air flow in your case i wouldn't think it to be an amazing idea. Why are you wanting to go passive? if it is down to noise, then an arctic cooler is pretty much silent anyway and cools very well indeed.
  3. DrillSgt
    15 Mar 2004
    I like the idea of total silence more then 'pretty much silent'.
    Years ago I knackered a brand new expensive video card in the process of removing the stock HSF, ever since then I've been a bit phobic about it.
    The case is reasonably well ventilated (praetorian).
  4. tank_rider
    3 Feb 2005
    So long as there is good airflow through the case it should be ok, they will have to have tested the design in a poorly ventilated case to prevent them recieving loads back on RMA.
  5. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Custom PC reviewed this (I think) and they said it was a brilliant card, but obviously it does need some air flowing over it! :D
  6. DrillSgt
    15 Mar 2004
    I installed it last week, it's great!
    No signifcant system temp increase, and the machine is now virtually silent, bliss!
  7. tank_rider
    3 Feb 2005
    Glad to hear its lived up to its expectations. Any chances of getting some benches as i'm going to be getting an X800XL in 2 months time and wondered if this one manages to retain the same performance as a regular, fan cooled, version.
  8. DrillSgt
    15 Mar 2004
    I managed 5054 in 3DMark '05 the other day, but I haven't updated it for a while, or tried the new catalyst drivers.
    You may find better benchmarks by googling for reviews, I did.
  9. DrillSgt
    15 Mar 2004
    Quick update, the card is in the process of being RMA'd.
    It died on Sunday, almost 1 week to the day after installation, I'm not impressed.
    I think I'll spend the refund on an Asus card and save up to watercool it instead.
    The whole point of getting the Gigabyte card was so that I wouldn't risk damaging it whilst trying to silence it.
  10. tank_rider
    3 Feb 2005
    Unlucky, i guess fanless cooling isnt such a hot idea on a high end card like that.
    Ill be getting a regularly cooled one then.
  11. Tim S
    Tim S OG
    8 Nov 2001
    Unfortunate news there buddy...
    Were you cooling it with any additional fans at all?
  12. DrillSgt
    15 Mar 2004
    Bah, sucks.
    I have a CM Praetorian, 2 80mm Vantec Stealths at the front, 1 at the back and another at the blow-hole. All connected through a Nexus controller.
    I have an EVO160 Rad behind the front fans, but it doesn't create much extra heat.
    The whole system was running pretty cool, I think I just had a duff card. I find it hard to believe it overheated, it certainly didn't fail while in use, it just failed to boot on Sunday.
  13. koola
    koola Minimodder
    11 Jul 2004
  14. DrillSgt
    15 Mar 2004
    I've ordered an Asus x800xl, I'll run it for a month, if all is well then I'll slap on one of these bad-boys:
    Linky :rock:
    As I said earlier, I don't like modding video cards, but if I'm forced to remove the HS/F, then I may as well include it in the H20 loop.
