Paste or Pads?
Discussion in 'Hardware' started by SJH, 17 Jun 2004.
  1. SJH
    SJH Minimodder
    24 Dec 2003
    Which should I use on my CPU, a thermal pad or thermal paste?
    According to the AMD website paste should only be used for temporary setups whereas pads are better when you don't intend to replace them anytime soon.
    Is it a case of AMD getting the facts wrong, or should I really use a pad?
    -Sam
  2. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    paste all the way.
    Cheers,
    Mike
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Seeing as you only require the very finest of layers, I would have to say paste.
  4. SJH
    SJH Minimodder
    24 Dec 2003
    Thought as much.
    Thanks! :)
    -Sam
