News Patch Tuesday brings 34 fixes
Discussion in 'Article Discussion' started by CardJoe, 6 Aug 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    As long as it's MS that's found these vulnerabilities and/or fixed them before they are out in the wild i say bring on the patches.
  3. J05H11E
    J05H11E Fujitsu Technical Analyst
    5 Aug 2010
    they were in the wild for a while before they were patched :/
  4. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Well, MS could leave vulnerabilities to fester 6 months before patching (like other companies) so this is damn good.
  5. Bob1234
    Bob1234 What's a Dremel?
    30 Jul 2008
    A lot of it depends on mitigating circumstances.
    Exploits that arent remotely executable or require some sort of specific user input are less significant than remote or automated ones.
  6. kzinti1
    kzinti1 What's a Dremel?
    13 Apr 2010
    As hackers evolve so does program security.
  7. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    I rub it then you do it
  8. ilikesimple
    ilikesimple AKA Scare100
    9 Jun 2010
    As program security evolves so do Hackers
  9. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    Let the patches keep coming, and to be honest telling XP diehards to go and get the final SP (seeing as they've now missed out on what, 80 updates unless installed separately) isn't unreasonable, is it coming up for two years old now? If you're going to use old stuff, it might as well be up to the last update MS is willing to give out.
  10. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I welcome the fixes but I will be making a restore point before I install them I think. I've had windows 'fixes' bugger my computer before now. So always best to have a restore point on hand.
  11. MitchBomcanhao
    MitchBomcanhao What's a Dremel?
    21 Jan 2010
    only 2 fixes on my w7 install. the rest were normal updates. I don't understand these news, if they do patches "I my god, so many patches". If they don't "oh my god, they're lazy and don't care about security, lets all use mac and linux".
  12. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Yes, I'm not quite sure why this is news. Slow week, Bit-Tech?
  13. Culinia
    Culinia What's a Dremel?
    17 Feb 2010
    I am not sure why this is news also. This is basic system maintenance.
  14. r0z|3o0n
    r0z|3o0n What's a Dremel?
    28 Nov 2004
    Perhaps if you look after a whole 2 home PCs with 1 user in total and a bunch of very standard software.
    The significant number of patches in one patch cycle is what makes this interesting for some audiences.
    Picture, if you will, testing and deploying this quantity of patches to, say, 3000 PCs spread over multiple sites, running a vast collection of horrible proprietary software that breaks about 50% of the time if an update touches the .net framework because it was made in 1996 and the vendor doesn't exist any more so getting support from them is like pushing wet sh!t uphill with a rake.
    Then your 'basic system maintenance' turns into hours upon hours of work for a team of professionals who are going to get shouted at if the software breaks when they patch.
Tags: Add Tags
