Hardware Patriot Wildfire 120GB review
Discussion in 'Article Discussion' started by Claave, 27 Jul 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. paz45
    paz45 What's a Dremel?
    12 Nov 2010
    Mushkin Chronos deluxe 120GB
    Maximum Read: 560MB/sec, Maximum Write: 515MB/sec, Random Write 4KB (Aligned): 90,000 IOPS, Controller: SandForce SF-2281
  3. Baz
    Baz I work for Corsair
    13 Jan 2005
    We've spoken to Mushkin about reviewing its drives, but it doesn't sell in the UK to my knowledge. Regardless, it'll likely be similar to the Wildfire; same controller, with slightly fancier NAND and possibly a tweaked firmware. I really don't think you'll be able to notice those extra IOPs in a home user environment.
  4. KiNETiK
    KiNETiK What's a Dremel?
    7 Apr 2011
    Aria have them in stock for 200 squid
  5. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    still not quite on the mark for $/gb only 1-2 years left.
  6. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    I have to admit that I totally missed the launch of 6GB memory modules and the firmware upgrade of s1155 to triple channel memory.... :p
    :hehe:
  7. Baz
    13 Jan 2005
    Clearly moved in on the sly. We'll get one in.
  8. Magnetar
    Magnetar Just Wasting Gigahertz
    2 Oct 2010
    From the Test Setup, Common Components section:
    Intel RST AHCI driver (msahci.sys)
    Intel's RST driver is iastor, and Microsoft's AHCI driver is msahci, both usable on the P67, so which one? A typo I presume.
  9. andrew8200m
    andrew8200m Modder
    4 May 2009
    The drive quotes IOPs on an 4K file over an 8GB LBA.
    Who in the world uses 8GB of data on a drive intended by most for boot? An OS for a start is pushing 14GB.
    That drive should have figures for an LBA covering 80% capacity which is a more realistic "real world" figure and as such not as missleading to those who may not be aware of this.
    An 80GB LBA would come in around the 50K IOPs area. The Mushkin uses Asynchronous NAND rather than the better higher quality Synchronous NAND as well making the drive on paper no different apart from the odd claimed MAX reads/writes than say the Agility 3 or the Force 3 rather than the superior Vertex 3, Kingston HyperX SSD or Force GT
  10. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Inconsistencies, probably typos:
    Page 3, graph 1:
    Title: Sequential read speeds
    Legend: Average write
    Which is it?
    Same thing on graph 6.
  11. law99
    law99 Custom User Title
    24 Sep 2009
    Two hundred sea creatures? I might have to book some time off work and sea if my mate by the sea is free!
  12. Jasio
    Jasio Made in Canada
    27 Jun 2008
    I bought my 120GB Crucial C300 SSD a whole 1.5 years ago for $200. Manufacturers are simply gouging on prices. As much as I'm not a fan of Apple- but their new Macbook Air's manage to drop in 256GB Samsung SSD's and the entire system retails for around $1400-1600.
    Maybe we need another large-scale lawsuit to shuffle prices a bit.
  13. SolidShot
    SolidShot Minimodder
    8 Jul 2011
    oh what a witty one we have here.. :)
  14. slothy89
    slothy89 MicroModder
    17 Feb 2011
    You say the Patriot is aiming at the top, and mention the Vertex 3 Max IOPS as being that top.
    Why then compare it to the 240gb vertex 3 vanilla?
    Shouldn't you compare the wildfire to the vertex 3 Max IOPS 120gb? Since from what I've read elsewhere the main difference between the 2 is the firmware. Same NAND, same controller.. Also capacity effects speed so a 120 vs 120 compare is in order!
    Reason I say all this, is at least in Australia, the max IOPS is $5-$10 more than the wildfire, and reflects the performance difference. But you do not cover this. Plus I still don't trust 25nm NAND lifecycle :p
  15. MyJuliet
    MyJuliet What's a Dremel?
    28 Jul 2011
    Intel iastor RST drivers, and Microsoft AHCI driver msahci, available both for P67, then which one? A typo I believe.
  16. maverik-sg1
    maverik-sg1 Minimodder
    18 Aug 2010
    These drive prices are simply too far out of reach, they are too expensive and appear to increase in cost with every new technology release - sure they are faster, but I'd be happy buying last gen products at a much better price, after all they are still 2x faster than a hard disk for an OS drive (apparently).
    .... anything over £0.75 per GB of formatted available space is never going to take the mainstream market, the first company to blink and make this offering will no doubt become the market leader in a very short space of time.
    Also - I think the review hit the nail on the head, all of these drives use the same controllers and it's incredibly challenging to justify buying anything but the cheapest model available for the same sized unit with the same controller.
  17. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    you can get an c300 256gb for around £300, seems good all rounded and has been out for an bit so bugs have been worked out
    really unless your doing server or some very time sensitive things, any ssd will do as long as its reliable and cheap (do not buy into the this ssds is 10-100mb faster then last ssd, the speed for the most part due to random read and write if its better then 20mb/s it should be good)
    most ssds your talking about 1-2 second boot between them (why most reviewers no longer bothering showing boot times any more ) only time I think they should be included if the ssd sucks like jmmicron first, second and 3rd go at it sucked (the 4th or current ones seem ok now as they are faster then an floppy drive at random writes)
Tags: Add Tags
