Case Mod - In Progress Paultan Designs: Titanium S
Discussion in 'Project Logs' started by paultan, 31 Jul 2013.
  1. paultan
    paultan R E V E N T O N
    22 Jan 2010
    :naughty:
    Hello everyone! now it's time for me to share the worklog of my latest build. The Titanium S.
    This is a collaboration work with my friend Ejay Bosquit where he is my first client. He really requested that I should build him a special modded rig and since he agreed that I will void every warranty of the parts that he will buy and I'm the one who will be deciding the entire look of the build, so I said "Yes! Let's build it."
    I let Ejay choose which hardware he will buy and use for this build since he has the budget to do so and basically he is the financer of this build. And on the modding and design part, that would be my responsibility.
    So let's start.
    First, I wanted to create a new Flagship for my Titanium family. And this will be perfect. It has no theme like the Titanium, just pure freedom.
    But this time it will be better. Better 90degree motherboard tray conversion, unique color theme, better layout and sexier look.
    That's why I called it Titanium "S". Because for some reason it's Special, Sporty, Sexy and and it's about Speed.
    Spec List:
    Rampage IV Extreme (in Black)
    Intel Core i7 3970X
    Cooler Master Cosmos II
    Corsair 16Gb 2400MHz DDR3
    EK Waterblocks
    2x Aqua Computer AirPlex 420 Radiators with Corsair AF140
    4x GTX780 Reference with EKWB
    EVGA Supernova 1500w PSU
    Samsung 840 PRO 250GB in RAID0
    Custom Copper Tubes (yes, that is copper tubing!)
    Rotated motherboard mounting
    Relocated PSU mounting
    Cheesecake sleeving
    So let's start modding!!!
  2. paultan
    22 Jan 2010
    I started, by murdering the Cosmos 2 Chassis by removing the center panel and converting the mobo tray to 90deg.
  3. paultan
    22 Jan 2010
    now for the mounting of the front 420 RAD
    at first this mounting was quite easy.
    But the problem is, according to Aquacomputer we cannot mount the rad that way because it will cause big problems to the pump. So we decided to mount it the other way.
    So I created a plate to hold the RAD.
  4. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Hells yes !!! looking forward to this!
  5. paultan
    22 Jan 2010
    After rotating the motherboard tray some modifications were needed.
    We will be placing a 2nd 420 Rad on the rear part so I decided to relocate the PSU in the middle of the chassis.
    Now I noticed that after removing the middle plate on the Cosmos 2 the chassis started getting weak. So I decided to do some reinforcements for the chassis.
    then test fitting for the custom side panel using my Dark Knight PC
    door handle.
  6. paultan
    22 Jan 2010
    now the tubes!!!!
    bending tubes are so difficult. but when you get the techniques it will be a lot easier.
    my attempts just to get the correct bend
    more fail bends
  7. KidMod-Southpaw
    28 Sep 2010
  8. paultan
    22 Jan 2010
    custom plates for water block.
    something is missing lol
    look where I placed it.
    paint job done :)
  9. paultan
    22 Jan 2010
    reinforcement chassis done!
    sexy!
    Asus Rampage IV Extreme (in black)
    only 2 were made. And I got the other half :) Thanks asus!
  10. paultan
    22 Jan 2010
    After 2 weeks of designing and modding! And 1 week of assembly!
    I proudly introduce to you guys, the result of our hardwork!
    TITANIUM S!
  11. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    :jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::jawdrop::jawdrop:
    icredible moddding!!! didn't se the yellow coming! :)
  12. paultan
    22 Jan 2010
    interior
    video card shroud
    relocated PSU
    back lighting behind the radiators
  13. paultan
    22 Jan 2010
  14. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Always modding on another level. Awesome work dude.
  15. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Paul you are a master modifyer and an inspiration to me. Hats off to another amazing build.
  16. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Just gets my rocks off.
    Wait that came out wrong. :worried:
  17. paultan
    22 Jan 2010
    Thank you so much guys :)
  18. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Superb!
    Excelent Job Paultan!
  19. revned
    revned What's a Dremel?
    19 Jul 2013
    Hats off to Paul! Great work man!
  20. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    :jawdrop:
    :jawdrop:
    :jawdrop:
    MOTM Here!
    Unbelieveable CRAFTSMANSHIP chap! :thumb:
    Look forward to the Next MOD! Thanks!
