Case Mod - In Progress PaultanDesigns: The Dark Knight PC - FINISHED
Discussion in 'Project Logs' started by paultan, 19 Nov 2011.
  1. paultan
    paultan R E V E N T O N
    22 Jan 2010
    a short recap of the build log :)
    Hello everyone, some of you maybe familiar with me and to this build. It's already done after a year. Finally! But I want to share to you some quick worklog for this build. So you'll have a better idea how I made the Dark Knight PC.
    I started last year when I got one of the first batch of the COSMOS II last October 2011 but actually started posting on January 2012.
    after that, I suddenly had the Idea to remove the handle bars to make it more sexier.
    and the Idea came out. (early photoshop concept art)
    after a while. The Dark Knight idea grew in me.
    another concept art
    90 deg rotated motherboard
    concept art for the side panel
    and concept art for the rear panel
  2. paultan
    22 Jan 2010
    Now let's head on to converting this case to 90 deg rotated mobo tray.
    First is to cut a big hole on the top and test where to actually set the mounting for motherboard.
    ooking good. now let's try to mod the motherboard itself.
    since it will be "Dark Knight" it will be a requirement to use all black parts as possible and to achieve that I really wanted to try to paint the motherboard to see if it's really possible.
    i used an asus Sabertooth 990FX board for this build since it will be my PC for work.
    removed the stickers
    then masked all the other parts, and painted it!
    and recorded a video if it will explode or will work
    https://www.facebook.com/photo.php?v=10150650284013424&set=vb.549793423&type=3&theater
  3. paultan
    22 Jan 2010
    now for the GPU
    3 Asus DCU II GPUs
    then after painting the heatsinks
    then later on I decided to cut it in half
    then for the special mounting! my original design Reverse GPU Mounting.
    then E22 saved my day. I had my design laser in aluminum by Nate
  4. paultan
    22 Jan 2010
    now for the corsair Airflow and Airflow PRO
    First initial testing of my design
    CLOSE UP
    2nd design
    Final Design and Result
  5. paultan
    22 Jan 2010
    then I removed the drive cages from the bottom and placed them on the upper front
  6. paultan
    22 Jan 2010
    now for the side panel design.
    my concept art.
    now for the execution
    looks succesful but the sidepanels aren't friendly
    so I decided to make my own sidepanel but making it from acryllic
    looks much better. we'll see much more of it later.
    jhanlon303 likes this.
  7. paultan
    22 Jan 2010
    now for the front panel
    I had to do it more than 3 designs and apply it on the front panel over and over just to get what really satisfy my taste.
    looks like an ironman case. not good.
    2nd attempt. fail again.
    and last attempt.
  8. paultan
    22 Jan 2010
    batman logo
    then the FRONT I/O Cover. Cut some old USBs and made this.
    and the end result is this
    teaser photo
  9. paultan
    22 Jan 2010
    rams
    back panel
    my concept art and design
    execution
    and then for the interior too
  10. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    fantastic job.
  11. paultan
    22 Jan 2010
    watercooling parts from AquaComputer
    so beautiful
    then murder it with black paint haha
    end result
  12. paultan
    22 Jan 2010
    sleeving
    then the PSU mod!
    AX1200 with the help of my friend Anthony with the soldering.
  13. paultan
    22 Jan 2010
    assembly
    the back
    the side panel
    then the label
    after 5hours assembly
  14. paultan
    22 Jan 2010
  15. paultan
    22 Jan 2010
  16. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Reading through this (finally) is a joy Paul. There is so many unique and inspirational ideas in here that you have executed perfectly. Great job and well done buddy!
  17. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    Beautiful work. Stunning photography too.
  18. paultan
    22 Jan 2010
    thanks Nate! Thanks phenoptix!
  19. paultan
    22 Jan 2010
  20. paultan
    22 Jan 2010
    I don't know what happened, maybe it's because of my white balance. the lights turned violet... hmmm... it's is white in person.
