Modding PC-12 Moral Dilemma
Discussion in 'Modding' started by Geek, 30 Nov 2001.
  1. Geek
    Geek What's a Dremel?
    21 Nov 2001
    Here's the problem, folks:
    I'm getting a PC-12 as soon as I get some money. I'm thinking of modding the front intakes to give them more breathing room. Should I do it? If so, what should I put there? A rectangle with rectangular ducting to the filter? Two intake ports? Also, would a red "Knight Rider" circuit be best mounted in the very bottom, or in that area between the 5.25" and 3.5" drive bays? (Of course, the actual project box can go anywhere - this would just be the LEDs.) Last question: I expect to eventually go to watercooling - will the two 80mm fans up front work as radiator coolers?
    Thanks!
    Gordon
