Case Mod - In Progress PC-Beto ( 23-12-2011 - MOTY nomination!! )
Discussion in 'Project Logs' started by p0Pe, 24 Nov 2009.
  1. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    no more waiting time;)
    And so it began! i started out with about 2.5 square meters of acrylic, and now have little left.
    I would like to thank my new sponsors, www.matronics.dk for sending me some AWSOME light for this project! f#ck ccfl´s. get some led strips from there :D i used them in my privious build, and the one they send me for this one takes the cake! RGB strips with wireless sound controller! Thanks! Tune in soon, and i will update the video with the light effects;) And thanks to bitspower for helping me out with some goddies that you all know whats gonna be;)
    some of the parts matronic sent!
    I also got the parts painted! matte black ftmfw!
    i used theese black rivets to rivet it all back together
    also got some wire stuff home;)
    now what is all this going to be used for ? :S
    THIS!
    that ended out like this. See all that wire? Its starting to make sense now huh?
    imagine all the little holes where there is wire in, like you see above
    that they be sleeved, so that every wire will look like this
    Now for the explanation.
    The 7 holes that sits in a square in the upper part of the cabletray is getting these inserted into them. You can then swap psu as crazy often as you like, since you dont have wires running in a maze through thousands of holes.
    Now for the fun part.
    I had to solder the correct cables to each of the 24 pin connector, since they were made with different lengths. Say hello to mister happy solder station!
    slowly, but certanly getting all the buggers on, and applying heatshrink on each, so that i wont have any fires in there -.-
    fans will have an output port like this:
    and the pump will have a slightly different one here:
    some of you have seen this pic:
    The thing that was in homers background is this:
    And it will be mounted like this on the backplate
    And how it was put on. I tapped 4 mm holes and used some black dome head 4 mm bolts i have.
    The dome head bolts will also be used on the front.
    And as you can see, the 24 wires is taking up quite a bit of space in the cable tray:/ dont know if i will be able to fit the 12 wires for the 6 pins, but i have to:D
    The fans also got some love
    And the 8 pin got sleeved. This will also be done to the 24 pin, and 6 pins.
    The little buggers in front is the clips that i had to use, to get the extender. took some time to get done, but it will be worth it!
    i think that was that for this update:) Next time i will have some more goodies to show you, some of them from my new sponsor, and a little something something that i got made instead of the res i have now;)
    worth the wait? If not, ill update again in a week or so;)
    Again, thanks to the sponsors ;)
    haakon.t, The_Beast, Floyd and 2 others like this.
  2. FrooP
    FrooP can I eat this?
    24 Oct 2007
    woah dude thats some serious modding thats going on here
  3. Attila
    Attila still thinking....
    22 Feb 2008
    Gee whizz p0Pe you have some seriously interesting ideas happening there. :thumb:
  4. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    ..."and i jizzed in my pants"...
    I'll get my coat
  5. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Thanks dude:D you need to get Q-vent done, so we can take it to DH :p
    thanks man! i loved your cygnus X1 build:D
    haha then you better close your eyes when i post the next update:rock:
    llamafur and Nutman like this.
  6. null_x86
    18 Jan 2009
    not in the eyes please!
    (again, ill get my coat)
    nice work though, this is really really good
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Whoah! Null is on a roll here!
    Oh, and the mod is stunning as well. :D
  8. stonedsurd
    11 Mar 2009
    The cabling idea is GENIUS. Have some rep.
  9. Azayles
    Azayles Minimodder
    6 Jan 2008
    +1! Have some more rep also. That cabling is slick as! Seriously epic win right there :thumb:
  10. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Crazy ideas in this blog! I like it!:D
  11. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Looking good! Are you sure that the plastic of the rear case will support the weight of the PSU like that?
  12. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Shite, how does one give 10+ rep???????
  13. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    This is hoss.
  14. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    you guys and that avatar is disturbing:D
    thanks man:D there is a lot of work in the cable system but i almost cant wait until its done:D
    thanks:D i want a clean and easy look when im done:)
    thanks:D
    the plastic is only to hold it in place:) there will be a support beneath the psu.
    push the bottom 10 times :D?
    glad you like it m8:clap:
    dex2407 and AnG3L like this.
  15. MugenUK
    MugenUK What's a Dremel?
    5 Aug 2008
    Flipping heck that looks cool, will be checking back on this for sure :)
  16. null_x86
    18 Jan 2009
    Glad to be of service ;)
    keep the good stuff coming p0Pe
  17. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Hey dawg that is .... that is.... omg what is the right word????
    FabuloFantasticAwesomeGeniouCrazyness modding there!!!!!!
    And congrats on the sponsors mate you deserve it.
    I am truly amazed man. Have some rep and stars!
  18. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I hate you for having such good idea
    BTW great cable management :thumb:
  19. Spyrious
    Spyrious Modding all the Time
    8 Dec 2008
    Amazing.Ingenious.Perfect.Impressive.Keep it up.
  20. Colossous
    Colossous Minimodder
    28 May 2007
    Great ideas duder :thumb:
