PSU Pc Build - Will this power supply do
Discussion in 'Hardware' started by LukeDaly, 8 Oct 2011.
  1. LukeDaly
    LukeDaly Pokemon Master
    9 Jun 2011
  2. Kernel
    Kernel Likes cheese
    29 Sep 2003
    More then enough :)
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  4. LukeDaly
    9 Jun 2011
    thanks man :) you sure? cause i really dont want it to bum out and have to buy another :(
  5. Blogins
    3 Aug 2010
    Why would you buy that when the AX850 is more capable and slightly cheaper?
  6. LukeDaly
    9 Jun 2011
    i dont pay for the electric in my house...
  7. Blogins
    3 Aug 2010
    Just because it's 850W that doesn't mean it's constantly drawing that amount of power! :D
    It'll only use what's needed for your computers components and the Corsair AX series are very well regarded as they are efficient. You might even make an energy saving going for the AX850 in comparison to the Antec!
  8. Kernel
    Kernel Likes cheese
    29 Sep 2003
  9. LukeDaly
    9 Jun 2011
    maybe i should go with this one?
    i want to be 100% sure ill be fine, my 2 gpu's will take 600watt alone on load
    although that antec says it is crossfire ready?
  10. murraynt
    murraynt Modder
    6 Jun 2009
    All the PSU's are good. That seasonic one is the one I would go for though, followed by the corsair.
  11. LukeDaly
    9 Jun 2011
  12. SirFur
    SirFur PC Gamer and LAzy B0nes
    8 Apr 2009
    I'd save the money and go for this corsair yes. Its a good PSU and will handle your requirements. If cost isn't an issue thats another matter...bit-tech's recent labs test may help your decision...they recently reviewed a lot of PSUs and they rated the Antec as their top choice (Antec High Current Pro HCP-750), but that isn't to say there aren't other good ones out there, I myself went for a slightly older but still great Antec Truepower 650 Modular.
    Hope that Labs test gives you a better idea and helps your decision.
    They may be out of stock, but its your best for the Antec at Scan for £130.
  13. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    You can run that setup on a 500w PSU, i dont see why everyone is recommending a 850w one.
  14. murraynt
    murraynt Modder
    6 Jun 2009
    True. Might as well spend the little extra if youre building this nice of a rig anyways :p
  15. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    You could but whats the point when go could get more wattage so it doesn't have to run at full load when gaming.
  16. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    The optimum is to get within the 70-80% load level where most PSU's are the most effective.
