ok untill they come out with more heatsinks for LGA775/socket T do you guys see a problem with taking off the cover and useing a 10inch fan to cool it? , will there be any dust issues if i do this and will this heat sink work for lga775 http://www.newegg.com/app/ViewProductDesc.asp?description=35-106-044&depa=0 edit: have any of you seen any cards that go in the pci-e 1x slot (i have 3 on my aa8, they look like lil back small versions of pci slots)
no problem with having the side off and using a desk fan to cool it theres not a great deal of PCI-E 1x cards out yet though
themal goup ok last thing then im done and gona order the new coolling parts what themal group stuf is the best right now im looking at http://www.newegg.com/app/ViewProductDesc.asp?description=35-100-007&depa=0 and http://www.newegg.com/app/ViewProductDesc.asp?description=35-100-008&depa=0 which is better?
Then why do you want to know which one is better Get the bigger one becasue it's not much more expensive and will go further.
