Motherboards Pc dead???
Discussion in 'Hardware' started by steveneedle, 22 Jul 2010.
  1. steveneedle
    steveneedle Minimodder
    2 Jan 2010
    Can anyone help...
    ive been having problems with my main pc/gaming rig for a few days...
    when i turn on the power supply and press the power switch it starts then maybe a second later it turns off, this will happen for several minutes and then eventually it will turn on....
    i went to turn it on today and nothing.
    i have a psu checker and when i plug the power supply into it it works correctly i think, if i plug the main 24pin nplug into it ...all the fans fire up that run off the psu , the hard drive starts an so does the dvd......
    i have a light on the motherboard when it is plugged in.
    is it a dead motherboard...or cpu???
    not sure what to try next
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    This is the same computer you overclocked with some nasty Alienware motherboard? Thats the thing I'd think of.
  3. steveneedle
    2 Jan 2010
    what???
    dont get what u mean...
    its a p5k3 deluxe with a 8400 running at stock speed.
    with a 8800gtx overclocked a lot.
    the cpu gpu and chipsets are all watercooled
  4. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
    First off have you tried clearing the CMOS by removing the battery on the mobo to reset your BIOS settings and remove any overclocks?
    Definately sounds like a motherboard issue though the same thing was happening to me when i accidentally shorted my motherboard out on a CPU backplate.
  5. steveneedle
    2 Jan 2010
    no i will try that now
  6. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Ph4ZeD, it isn't the same person, that was someone else :)
    Do you have a speaker plugged into your motherboard? Do you get any beeps or anything? Or literally nothing? If so...sounds like a dead motherboard to me :( This is after clearing CMOS, btw :)
  7. steveneedle
    2 Jan 2010
    ok i tried that ...left out for about 1 min.....
    still no different
  8. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    Does the GPU starts? cant you hear the beeps from the system booting up?
    Is your reservoir inside the case close to your GPU?? I had a watercooled system before, my reservoir was inside the case and overclocked the GPU, the temperatures went up and some evaporation caused problems on my MOBO.
  9. steveneedle
    2 Jan 2010
    i dont have any speakers plugged in.....
    no when i try an turn it on there is nothing.....if i use my psu checker the fans, hard drive an dvd all start
  10. steveneedle
    2 Jan 2010
    no the res are all filled up i did that about 2wks ago....when it was running liquid was only at 35c...
  11. steveneedle
    2 Jan 2010
    is it the mobo??...
    how do i know if the cpu an ram are ok?
  12. paisa666
    4 Mar 2009
    well the best way to discard your cpu and memory from any damage its trying them on another mobo
    maybe a firnd of you could help you or something
  13. steveneedle
    2 Jan 2010
    does it sound like the mobo is dead thou??
  14. Jipa
    5 Feb 2004
    That's the most likely candidate.
  15. paisa666
    4 Mar 2009
    Yup:(
    Sorry, sounds like a dead mobo
