CPU Pc failing to power up properly
Discussion in 'Tech Support' started by Leesy1, 4 Jul 2015.
  1. Leesy1
    Leesy1 What's a Dremel?
    6 Nov 2009
    Hey all. I purchased a MSI 980 ti and received it yesterday. I have just put it into my pc and hooked up the 2*8pin power connectors. (It has replaced my 680 evga card). On power up everything powers on for 2 seconds and then turns off.... The worst part is I have put my 680 back and now that does the same thing
    There is a motherboard power led which is green showing it has power. Then there is a Cpu led on the board (Asus p8z77-v pro). This briefly lights up red when the power turns on for 2 seconds.
    I'm very careful when putting parts into my pc. I use an anti static band etc. The only thing that happened was a drop of sweat (gross I know) fell onto the motherboard. I used a small towel to dab it off. (All power was off when I was doing this). Surely that couldn't of busted the board or cpu?
    Any ideas would be great,
    Thank you, Lee
  2. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    What psu do you have? MAke sure the GPU is seated correctly, if in doubt remove it and reinstall it.
  3. Leesy1
    6 Nov 2009
    I have had two gpus in there. They both power up for 2/3 seconds along with the corsair cpu cooler. There deffo seated correctly.
    I have a corsair 850 hx or ax. One of them :).
  4. LennyRhys
    LennyRhys Oink!
    16 May 2011
    I've had this symptom twice in the past, and there have been two reasons for it:
    1) something is causing a short on the motherboard (sweat could do it, seriously!)
    2) the CPU is dead
    I hope that it's 1), which is relatively easy to remedy. Have you tried the age-old solution of removing all ram modules except just one? And what about removing the MB battery to reset CMOS?
  5. TheMadDutchDude
    23 Aug 2013
    It could also be an incompatibility with the GPU and the motherboard.
    The CPU dying is incredibly unlikely, they are genuinely extremely difficult to break. Trust me, they aren't that fragile.
    Can you put your old 680 back in to see if the rig boots? Have you tried using another PCI-E lane?
  6. Leesy1
    6 Nov 2009
    I'll look into the ram/cmos Lenny.
    I have put the 680 back in and have the same problem. I'm leaning towards motherboard or cpu issue. I don't think the gpu is incompatible as I had a 980 work in it last Xmas but decided to return it and wait for the Ti or equivilent. I had to upgrade the bios. It all worked fine.
    I really am beginning to think that bit of sweat has buggered it which is crazy.
  7. Teelzebub
    27 Nov 2009
    I would take it all out of the case and place on a cardboard box and see if it will boot up outside of the case, if not then likely the mobo
  8. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Try a different power connection from the PSU to the GPU for starters. In my experience the AX850 is trash. Been through three RMA/Replacements with mine and it looks like a fourth is on the horizon!
  9. Leesy1
    6 Nov 2009
    I took the CMOS battery out and put it back in and no luck. In fact it won't even power on at all now. I do have a Corsair AX850 Bloggins. I think i'll ring Scan tomorrow as it's one of there systems. It's out of warranty though. According to there site I can pay to get it fixed though.
  10. Blogins
    3 Aug 2010
    The AX units have a 7 year warranty so I don't think SCAN will be out of pocket getting this replaced!
    Plead to their better nature! :thumb:
    My faulty AX units had the same sort of problems until they refused to turn on ever again.
  11. Leesy1
    6 Nov 2009
    Ah, i'll mention it to them. I'll see what they say tomorrow :).
    Thank you all for all the help .
  12. LennyRhys
    LennyRhys Oink!
    16 May 2011
    No probs = that's what BT is for! :thumb:
