Other PC fan oil
Discussion in 'Hardware' started by gingbeard, 8 Nov 2009.
  1. gingbeard
    gingbeard What's a Dremel?
    6 Nov 2009
    Ok, so here is a good question - What is the best oil to use to libe up those dusty PC fans? Hair clipper oil?
  2. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    I'd just replace them... or use a vacuum cleaner
    Some oils will eat through the plastic as well, so I wouldn't try any out at all
  3. kenco_uk
    28 Nov 2003
    I was told sewing machine oil worked well.
  4. stonedsurd
    11 Mar 2009
    Yup sewing machine oil is fine.
  5. kimandsally
    kimandsally What's a Dremel?
    28 Jun 2005
    You have to strip the fan right down and take the fan impeller out of the frame then clean the shaft properly, it takes like 30 seconds you need a sharpe instrumant to peel out the plastic clip that holds it togther.
    Then a small amount of any thin oil like 3 in 1 will do great, I take mine to pieces about every year and clean and oil them, my 120mm fans are 4 years old and still OK, I think they run nicer after the first strip down and oiling maybe they are run in?
  6. Krikkit
    21 Jan 2003
    Gun oil would work nicely as well if you have any.
  7. Elton
    23 Jan 2009
    WD4D?
    Sewing Machine oil or Gun Oil works pretty well too.
  8. gingbeard
    6 Nov 2009
    Gun oil you day?Yes - got that! Lots of online threads say that WD-40 is the worst thing you can do - not good for the fan at all. Could this be true?
  9. kimandsally
    28 Jun 2005
    I would be bad if you just sprayed the fan with it hoping it will get in, if you strip the fan down as I have said to do then it will be fine just on the bearing surfaces.
    If it gets on the plastic it will probably rot it eventually.
  10. Krikkit
    21 Jan 2003
    WD-40 isn't very good for this kind of thing, it tends to destroy any grease that's left. I suppose ideally you would just use axle grease.
  11. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    WD40 is not a lubricant, it's a water displacer (hence the name)
  12. tk421
    tk421 Idiot.
    15 Jan 2002
    try a silicone-based paintball marker lube. the cheap stuff.
    won't eat plastic, etch anodized aluminum, or anything like that.
    also, dry graphite might work in a pinch, but wont last that long ...
  13. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    This could be a good thread, I'd like to know how to "improve" my fans to lower noise etc...
    Please could someone post an idiot's guid to stripping, cleaning, lubing and rebuilding a fan?
    Many thanks,
    Cleggy.
  14. capnPedro
    11 Apr 2007
    DOW-33
  15. Krikkit
    21 Jan 2003
    I may write one this week, but for now have a look here for a guide which includes stripping a fan. For lubing just oil the shaft (*snicker*).
  16. Elton
    23 Jan 2009
    My bad.
    For some odd reason I was looking at a container of gun oil, and even worse thought it was WD4D..
    Need to label my stuff..
  17. tk421
    tk421 Idiot.
    15 Jan 2002
    no, no DOW 33 or 55, or hater sauce, or any expensive lube. a $3 bottle of spyder or tippman oil ... or gold cup gun oil if you already have it.
    i'm sure the DOW would work, but it would involve tearing down, greasing, and rebuilding. the oils, 1 drop, good to go
  18. capnPedro
    11 Apr 2007
    My bad. 1/4 oz of DOW-33 is like $2 and is made of silicone so I thought that was what you were talking about.
