Other PC fan spins for one second and stops - No bootup
Discussion in 'Tech Support' started by cjgsilva, 11 Nov 2010.
  1. cjgsilva
    cjgsilva What's a Dremel?
    5 Oct 2010
    Hi People,
    I had to come to u guys. U always are helping every one so i hope u help me too.
    I have a pc the does PC Fan Spins For One Second And Stops.
    Now I read something’s on the internet.
    And I have now removed all hardware and unplugged all components.
    And it boot all ok but as soon I connect anything like hard drive or gpu or dvd it just does the same one second spin.
    What I am missing?
    I very grateful for any help u can give me.
    I have an m2n sli deluxe and an amd 78XX be
    PSU is a cheap 650w one.
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Buy a good one, then come back if it still doesn't work.
  3. bulldogjeff
    2 Mar 2010
    Agreed it defiantly sounds like the PSU
  4. cjgsilva
    5 Oct 2010
  5. markbrett64
    markbrett64 thanks to denial I am now immortal
    12 Jan 2010
    Could be a short. Check the posts the motherboard is sitting on in the case, are they all the same height an in the right places?
    Can you assemble all the components outside the case to see if it works?
  6. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
  8. cjgsilva
    5 Oct 2010
    this is more for the old comp amd 2600
    but serve for me to run test on this machine like u said!
    i was looking more into buying this one
    http://www.novatech.co.uk/novatech/prods/components/powersupplies/Corsair/CMPSU-400CXUK.html
    but only when i think all is ok mate.
    times are hard got to trie and save money
    is this one better ? all together is 35.33 not a bad price?
    and could i run this card with it?
    http://www.scan.co.uk/products/1gb-...shader-1700mhz-336cores-2xdl-dvi-i-1xminihdmi
    just dont kill a guy because off a PSU... ok!!!
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Why is "cheesecake" inserted into that last URL? :eyebrow:
  10. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Word filter win/fail
  11. wormy
    wormy Minimodder
    16 Oct 2009
    sounds similar to a problem i had - cpu cooler fan wouldn't spin, though fans directly connected to psu and psu fan itself would. Mobo board power light came on but nothing else would start.
    PSU currently (subject to courier depot not having lost it - in process of checking that...) with BeQuiet! for warranty testing...
    It can happen to supposedly good PSUs too.
  12. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    Honestly it sounds you like are having a boot failure more than a bad PSU.
    Boot failures can be caused by.
    1. Unstable overclock.
    2. Unstable memory.
    3. Short circuits.
    4. Loose connections between memory or other add-in cards.
    Try checking connections and resetting CMOS before buying stuff.
    You can reset the CMOS but reading the manual instructions or the for sure way is just pop the motherboard battery out for 30 seconds.
  13. wormy
    wormy Minimodder
    16 Oct 2009
    I've done that on mine Waffle, and tested it out of the case. Starts up fine with another psu...
  14. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    But he needs a reliable PSU anyways so we might aswell get that out of the way.
    @OP Yes, the CX-400 is an excellent power supply, get it while you can, it's discontinued nowadays.
  15. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    Have you put the RAM back in?
    It sounds too daft to be true but I rebuilt my machine and wondered why it would only run for a second before powering down, only to realise I had left the RAM out. DOH!!
  16. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Happened to me on my old amd 3700 system, the el-cheepo case somehow warped my motherboard so the gpu wouldn't sit properly. When it wouldn't sit properly it would start, fans spin up for roughly 1-3 seconds than turn off. After taking the entire pc apart and installing on a box I noticed that the gpu wasn't sitting in properly. Bit of man-handling and pushing to try and flatten the motherboard and it worked just fine. Make sure everything is seated properly in their slots / all connections are proper.
