Other pc freezing while gaming
Discussion in 'Hardware' started by chimeradog, 29 Aug 2010.
  1. murraynt
    murraynt Modder
    6 Jun 2009
    Looks like a dodgy hdd, RMA it.
  2. chimeradog
    chimeradog What's a Dremel?
    1 Jun 2010
    something quite noob to ask...i run furmark with xtreme burning mode in default resolution....is it correct to use these settings to check the stability of the gfx or should i turn off xtreme burning mode?
  3. chimeradog
    1 Jun 2010
    ok now i did a reinstall of win 7 on my master hard drive which is a little dodgy....but it still fails the seatool short test.....so should i RMA it? or is there any other ways to rescue it?
  4. adam_bagpuss
    24 Apr 2009
    Just rma it as it will only cause you issues
    Oh and seatools tests the drive not Windows so a format wouldn't have changed anything
  5. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    have you tried swapping the sata cable and running seatools?, before you rma it
  6. chimeradog
    1 Jun 2010
    i've tried swapping the sata cables and still my drive fails the seatools tests
  7. RichCreedy
    24 Apr 2009
    then definately rma it
  8. chimeradog
    1 Jun 2010
    ok...probably will rma it tomoro or the day after
