PC hard rebooting
Discussion in 'Tech Support' started by Kehoe, 19 Nov 2017.
  1. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    Hi guys really hoping someone can help, Long and short my depression and anxiety have let my pc beat me, i personally know if i try any more a brick will end up in this thing,
    About 3 months ago my pc would randomly blue screen once in a blue moon,
    Its now hard rebooting,so power cuts out and it reboots, I've swapped my GFX card as this was initially @ fault tested this on another machine, however the pc is now doing it with a new gpu, i went from a 1080 to a 1050ti to test. i've removed everything bar one stick of ram, all the hdds, the motherboard Qcode shows no errors, i've even resorted to a full clean install of windows.
    Photo from bios just before i removed the ram, I've reset and updated bios.
    When i now trying to load windows (clean install) it gets to a about 2 mins in and then reboots
    once i get back in im greeted with this message, so i am currently defeated, this is my main source of escaping so kinda lost without it,i've always taken it to my local pc shop if i couldn't sort it my self but they closed down a few weeks ago
    Any help would be greatful
    Many thanks
  2. RedFlames
    23 Apr 2009
    That looks like it might be a SSD/HDD issue... Assuming it is connected to the network like it's asking for...
  3. Kehoe
    Kehoe Minimodder
    9 Aug 2015
    Although id removed the sata cables from all my mechanical drives, id never removed the power cables, since doing that the pc is loading into windows, so im currently updating it and since all the hdd's are over 5 years old im going to replace them, they are mainly 500gbs so time for an upgrade, i assumed removing the sata cables would be enough
  4. BU5H W00K1E
    BU5H W00K1E Minimodder
    18 Nov 2017
    i had a very similar problem and mine ended up being the extenders i was using for some reason when gpu needed any power above idle it would hard restart the pc but after removing them it's fine
