Hardware PC Hardware Buyer's Guide July 2011
Discussion in 'Article Discussion' started by Lizard, 11 Jul 2011.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. chrismarkham1982
    chrismarkham1982 Multimodder
    1 Apr 2010
    waits for comment about why amd's new cpu hasnt been used instead :rolleyes:
  3. Kris
    Kris Lord Lolwut
    6 Jun 2008
    actually, I would just add that instead of a gtx590 (that might blow up on you), you'd be better off with xfired 6970 cards, it would save you a good amount of money while performing faster and consuming a lot less power at the same time. What's not to like?
  4. slothy89
    slothy89 MicroModder
    17 Feb 2011
    Watercool the 590, problem solved :)
    Regarding the article:
    I'm just jealous PC Hardware isnt this cheap in Australia.. It cost me around AU$2,500 to build something that performs similar to the Gaming Workhorse..
  5. chrismarkham1982
    1 Apr 2010
    bit-tech dont like multi gpu set-ups normally
  6. Anneon
    Anneon What's a Dremel?
    30 Sep 2010
    Gaming Workhorse -
    I recently bought a M4 64GB SSD. I have to agree it is the most worthwhile upgrade I have carried out in a long time. Windows boot time, game loading times (levels, initial loads) and general program loading times has been drastically reduced. Will never go back to a mechanical main drive.
  7. rollo
    rollo Modder
    16 May 2008
    What's the did between duel core gpu and crossfire they both use similar drivers
  8. Elton
    23 Jan 2009
    Premium player Septemeber 2010? That's interesting they have some new hardware in the past. :D
    By the way nice as always, although you might want to recommend a CPU cooler for the US crowd. Thermaltake Frio perhaps?
  9. hurrakan
    hurrakan What's a Dremel?
    13 May 2010
    Is the motherboard Z68 or P67 ?
  10. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    The 590 is here because it was faster, quiter and cooler than the 6970. After thorough testing by Bit-tech it was the better option.
  11. Elton
    23 Jan 2009
    On another note, have they fixed the 590 explosion thing yet?
  12. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    I'd quite like to see an amd equivalent for each system, sure you might not get spec-for-spec identical comparisons, but something in each level, to show a price difference or offer a broader choice of just buy intel would be nice. I'm no fan boy (switching from p4 to amd XP to amd 64 to intel quad and back to amd quad) i just go on bang-for-buck at the time
  13. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    At the risk of coming across as slightly arrogant, I think the ball has been somewhat dropped by the Bit-Tech boys, with regards to the Affordable All-Rounder. Changing out the Pentium for the i3-2100 is a bit of a sideways step (I'd normally stick to overclocking-friendly parts on budget builds to eke out that lovely performance), but understandable if an upgrade path is desired.
    And then it gets a swift kick to the chops by using an H67 motherboard. Really, guys? You recommend an upgrade path through LGA1155 with ZERO chance of using the i5-2500K? To add insult to injury, you take one of the most frugally-powered desktop chips on the planet, and attach a Freezer 7 Pro. For the extra £15, you could have a P67 motherboard, right?
  14. rv88uk
    rv88uk What's a Dremel?
    28 May 2011
    In the premium player you seem to be using 3 SATA III drives (SSD + 2x 2TB WD Caviar Black HDDs), however the Asus Maximus IV Gene-Z only has 2 SATA III ports. Is there any performance decrease from using SATA II with the 2TB drives?
  15. StoneyMahoney
    StoneyMahoney What's a Dremel?
    10 Jul 2009
    Holy CRAP! You're right, it is cheap (and amazingly small) for a card with more RAM than I have hard drive space!
  16. Guest-16
    Guest-16 Guest
    Any hard drive doesn't need a SATA 6Gbps port frankly. Only SSDs do :) Buffered results don't count. ;)
  17. Xir
    Xir Modder
    26 Apr 2006
    Pssst, the much-anticipated Z68 is not to be mentioned :D
  18. chrismarkham1982
    1 Apr 2010
    as far as i remember no HDD maxes out sata 3gbps let alone sata 6gbps, only ssd's make use of the extra bandwidth the new sata standard gives.
  19. nathanieltonge
    nathanieltonge What's a Dremel?
    8 Apr 2011
    Why use a cheap sata DVD drive in the premium rig? I think a blu-ray player would be the way to go.
  20. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    ok, how does the A8-3850 compare when run with the HD 6670 (to create a HD 6690d2) compared to the choices you made for processor and graphics card? Just interested as no one seems to have posted that on the web that I can find yet...
Tags: Add Tags
