News PC Hardware Buyer's Guide May 2010
Discussion in 'Article Discussion' started by Sifter3000, 7 May 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
    How come the Bit-Tech site buyer's guide differs from the CustomPC mag buyer's guide? Aren't you guys in the same office?
    My last build I did use a combination of the two but I still was left scratching my head on a few components.
  3. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    I know it must be a pain putting this up every month but want you guys to know that we appreciate it!
    Any chance we can have the best monitors/speakers for those ranges too? That would be cool ;D
  4. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    I wonder when we will see a significant change in the hardware recommendations!
  5. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    When Sandy Bridge is out?
  6. Pete J
    Pete J Employed scum
    28 Sep 2009
  7. cybergenics
    cybergenics What's a Dremel?
    27 Jun 2009
    i7 920 still widely available......sometimes as much as £65-£80 cheaper than a 930...lots of people have not been able to clock the 930 higher than the average 920 d0 did. So why is this recommended ???????????????????
    Someone explain ? BT have recommended parts far rarer than the 920, so please don't use its 'scarcity' as a reason, as this guide is month to month.
    Obviously retailers have higher mark up's on the 930...if BT is unbiased, the should be pimping the 920 at the bargain cost it is !
    Good guide overall though.
  8. Rob Lang
    Rob Lang What's a Dremel?
    23 Jun 2009
    Any chance of a HTPC/media PC build?
  9. rollo
    rollo Modder
    16 May 2008
    It's what I'd of suggest
    920 was £160 on overclockers last I checked
    What do you gain on 930 for the extra cash
  10. matee
    matee What's a Dremel?
    12 Feb 2003
    Yes I also thought you could either squeeze much cheaper 920 into Gaming Workhorse, or put it into Premioum Player, to get more ram or a nice dinner for two.
  11. shah
    shah Minimodder
    29 Jan 2010
    +1
  12. Deadpool46
    Deadpool46 What's a Dremel?
    28 Jul 2009
    Probably not a huge deal with the Premium Player but FYI; Overclockers has a fair amount of 5970 stock, starting at £499.
    Still a lot of money but as it's the Premium Player you might as well go premium.
  13. wyx087
    15 Aug 2007
    £90 P55 vs £155 X58, i think money is better spent elsewhere with gaming workhorse. and obviously Bit thinks the same.
    remember that this is a monthly buyer's guide, and 920 has been EOL'd. so it could run out of stock before the end of month.
  14. Kasius
    Kasius Bringin' the dremolition
    16 May 2003
    Also interested around the comparable differences between the 920 & 930 given the price offset..
  15. Sifter3000
    11 Jul 2006
  16. rollo
    rollo Modder
    16 May 2008
    920 and 930 are nearly identical
    Bit tech has there perfoance scores
    from what I remember if you clocked the CPUs to both the same speed the dif was 0
  17. Kasius
    16 May 2003
  18. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    I think I can squeeze a 5850 in your enthusiast overclocker build.
    As this build is geared towards gaming, I believe the gfx card will have the most impact on performance and experience. Therefore, I would suggest the following replacements -
    1. The i5 750 with an i3 530 ( or if one has an AMD build, then probably a phenom ii x2 550 or an athlon tri core) - Games at high resolutions of 1680 X1050 and above are more GPU dependent than CPU dependent.
    You Save - £45.85 (price source - scan.co.uk)
    2.Replacing the 1600Mhz RAM with 1333Mhz - This could limit the CPU overclock, but as clearly highlighted by this article (http://www.tomshardware.com/reviews/core-i3-gaming,2588.html) the core i3 at stock and overclocked perform very similarly. Moreover, RAM speed alone does not have a significant impact on gaming performance.
    You Save - £30 (price source - BT's May buyer's guide)
    3. Replace the modxstream500w with a stealthxtream 500w - Modular PSUs usually cost more than their non-modular counterparts. You can save £10-£15 when buying a non-modular PSU. Moreover, high end cases like the Utgard have a lot of space for unused cables.
    You Save - £7.49
    (Price source -
    Modxstream - http://www.amazon.co.uk/dp/B001GLFD...ode=asn&creative=7974&creativeASIN=B001GLFD4U
    Stealthxstream - http://www.scan.co.uk/Shop/Computer...40-Cores)/ATI-Radeon-HD5770-PCI-E-(800-Cores)
    Total Saving - 83.34
    The cheapest 5770 (on pre-order) is for 116.29 (http://www.scan.co.uk/Shop/Computer...40-Cores)/ATI-Radeon-HD5770-PCI-E-(800-Cores))
    The cheapest 5850 (on pre-order) is for 223.23 (http://www.scan.co.uk/Shop/Computer...40-Cores)/ATI-Radeon-HD5770-PCI-E-(800-Cores))
    Thats a price difference of £106.94 which is £23.6 more than our total savings from above. In other words, my build costs £23.6 more than the enthusiastic overclockers build, but I am pretty sure it would perform much better and would be more future proof,provided you are willing to spend
    Now if only someone could test this for me :) because I dont have any money :(
  19. rickysio
    6 Jun 2009
    Core i5 750 is a better all rounder, though.
  20. Xir
    Xir Modder
    26 Apr 2006
    Considering: does-anyone-really-need-a-1kw-psu/
    Why is the Premium Player equipped with a 750 Watt PSU, or the Gaming Workhorse with a 650 Watt?
    The combination i930+HD5870 or i860+5850 shouldn't drai near that much power..
Tags: Add Tags
