Hardware PC Hardware Buyer's Guide May 2011
Discussion in 'Article Discussion' started by arcticstoat, 10 May 2011.
  1. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    The 560Ti needs 31A in total but it doesn't have to be from a single rail. The Antec TruePower New 650w has four rails, two of which can be used for GPU's and each is rated at 25A.
    You need to connect the PCI-E cable with the blue stripe (non-modular cable) to one of the 560Ti 6-pin connectors, then use the modular PCI-E cable with the green stripe to connect to the other 560Ti 6-pin connector. This cable with the green stripe needs to be plugged into the socket on the PSU marked 12V4.
  2. Toga
    Toga New Member
    5 May 2011
    Ooh, brilliant, I'll give that a shot tomorrow then. Appreciate the help guys.
  3. Toga
    Toga New Member
    5 May 2011
    Right, tried it out & still the same problem, crashes between 15-30min after boot while either watching youtube or playing a game that draws a lot of resources. I've found an old 850w non modular power supply with a single 12v rail at 38A, so gonna give that a try tonight.
    Is there anyone here that's successfully using that card with that psu?
    Edit: moved this to it's own thread, don't wanna clog this one up. http://forums.bit-tech.net/showthread.php?p=2710702#post2710702
  4. bumperbid
    bumperbid New Member
    18 Feb 2011
    Genaral
    use the Google dev
  5. CrazyJoe
    CrazyJoe Well-Known Member
    4 Aug 2010
    Will there be a June guide?
  6. tad2008
    tad2008 New Member
    6 Nov 2008
    Just bought the Radeon 6850 to replace my 8600GTS, based on the reviews and buyers guide here on BT, turned out to be cheaper than the 460 and am currently enjoying playing through Witcher 2 again, this time on High settings and AA turned on, though CD Projects settings still wanted to use the low options.
    A much better game experience for me and thanks BT for the recommendations ;)
  7. elalcaudon
    elalcaudon New Member
    23 Jun 2011
    In all honesty, my preferences were pretty much what everyone else would have used the relevant builds for. The only thing I did change on the Gamer was the PSU since I couldn't get one due to stock shortages but I used the recommendation in the CPC mag which sometimes wierdly differs from the Bit-Tech recommendations.
  8. facwit
    facwit New Member
    24 Aug 2010
    When is the June/July guide going to be out?
  9. rainbowfication
    rainbowfication New Member
    14 Jun 2011
    will there be a July guide? i know there wasn't much change last month any change soonish
  10. toolio20
    toolio20 New Member
    29 Jan 2011
    There should be no June guide, since we are in July. The way things are going, I'm srsly doubting they'll even put out one for this month. I'd be thrilled to be proven wrong, though (cough cough ahem etc).
    BT's buyer's guides were always one of my favorite articles, it seems ridiculous they've let them slide so far to the wayside...maybe they'll get back on track at some point?
  11. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    There was no point in putting one out for last month. There was no new hardware. Last I heard on the subject they do have some new motherboards to test and then we should see a new one.
  12. facwit
    facwit New Member
    24 Aug 2010
    Why cant they just post a comment - no new kit to test this month. Next guide is coming in August.
Tags: Add Tags
