Hardware PC Hardware Buyer's Guide May 2012
Discussion in 'Article Discussion' started by brumgrunt, 18 May 2012.
  1. mikkig
    mikkig Big Giant Robot
    1 Jul 2008
    Have we got to the point now that there isn't a need for a Highpoint card to run the SDD and hard drives off at 6gps?
  2. rollo
    rollo Modder
    16 May 2008
    sli 680s with the same cpu you mensioned used less than 500 watts of power in an andtech review under full load and that was whilst overclocked to the hilt (http://www.anandtech.com/show/5787/...y-bridge-and-nvidias-geforce-gtx-680-in-sli/4)
    what in the crazy world do you need 1200 watts of power for in the premium player overkill is not the word id use.
    most new mobos have native 6gbs ports that are faster than the high point card that was needed in the pre sandybridge days.
    SSDs in most systems is nice to see wont be longer before its every system i feel now
  3. Baz
    Baz I work for Corsair
    13 Jan 2005
    The Intel SATA 6Gbps ports included in the p67, z68 and 77 chipsets are actually faster than the high-point card, so yes. And 6gbps HDDs are pointless, as they don't even approach the speed limit of SATA 3Gbps.
  4. Arghnews
    Arghnews What's a Dremel?
    6 Jul 2011
    If you type in to Google, "Bit Te", the 2nd option recommended is the Buyer's Guide, after the site itself of course. I think that shows how popular this is, glad to see it back! And please put out one every month!! :D
  5. Combatus
    16 Feb 2009
    I can see we won't get away with this ;) so I've revised the PSU option to the 850W model. We haven't tested the exact model but we have tested its big brother so we'll relent (we haven't tested anything above 750W for a while). The 1200W model was a left over from our recommendation to buy the GTX 590 3GB which was a monster.
  6. Ljs
    Ljs Modder
    4 Sep 2009
    I must be invisible.
    THE POWER!
  7. j_jay4
    j_jay4 Minimodder
    23 Apr 2009
    Well if it was a HTPC which can handle gaming as well you can just put the gaming workhorse in an ATX/mATX HTPC case with a suitable heatsink so I don't think you should have high end hardware.
    It would be interesting to see if you chose a mATX case or something smaller because having a full size PC under your TV kinda defeats the point. It needs to be compact, quiet and aesthetically pleasing.
    Would really look forward to seeing what you come up with.
  8. Combatus
    16 Feb 2009
    Not at all Ljs - our decision was based on your comment too! It's just we have more important things to do than monitor this thread every 0.1 seconds ;)
  9. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Why aren't monitors included? Whilst most people would keep a monitor in between upgrades, it would be nice to include monitors that match the different budgets/scope.
  10. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    I imagine Bit doesn't review enough monitors to be able to make an accurate recommendation.
  11. B1GBUD
    29 May 2008
    That's totally inexcusable and needs addressing!
  12. Monad
    Monad What's a Dremel?
    14 Sep 2011
    Going by this logic i don't understand why the the 3570K isn't recommended over 3770K is or at least mentioned.
    3570K gives off better fps in games according to what i've read so far and the price difference is pretty big.
  13. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    Really happy to see this feature back. Also really happy to see the system I built and the gaming workhorse are more or less the same, means I must have done a decent job is selecting parts. Really done see the need for an additional sound card for the gene v systems though. The on board is already a fantastic piece of kit, and is electronically isolated so distortion is at a minimum. Each to their own i guess :)
  14. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Awesome, so glad to see it back. One thing I noticed though - cut/paste fail from previous guide in the Enthusiast Overclocker:
  15. Combatus
    16 Feb 2009
    But no where near as big as the price difference between the 3770K and a high-end LGA2011 CPU - you're talking less than £80 compared to £600. There's next to no difference in games - at least in our benchmarks, which is all we can comment on of course. At stock speed the 3770K was faster, and even when the 3570K was overclocked 200MHz faster (we're seeing quite a bit of variance in overclocks too) the 3770K was just a couple of fps behind.
    Elsewhere, whenever the 3770K gets its hyper-threading into gear, in Cinebench for example, it's a lot faster than the 3570K. We're assuming that if you're spending over £1,500 on a PC then you'll be wanting it for demanding tasks other than games such as rendering and video encoding, and here the 3770K is definitely worth the extra £80 in our opinion. It's less than 5% of the cost of the PC after all.
  16. Combatus
    16 Feb 2009
    Thanks! Sorted!
  17. davefelcher
    davefelcher What's a Dremel?
    14 Aug 2009
    Any chance you could recommend an ATX motherboard option for the Premium Player? I was planning on Going SLI which would mean no room soundcard, TV card etc.
    HTPC guide is a great idea. I don't play games on mine, I just like it to be low power and as quiet as possible whilst being able to record TV, play 3D Blu-rays and the like.
  18. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Good guide, and as other people mentioned, it was one of the reasons why I came here :)
    What SSD would you recommend for the Enthusiast build?
  19. WildThing
    WildThing Minimodder
    26 Jul 2007
    Glad this feature has made a return as it has helped me out a lot in the past. Thanks Bit-tech dudes!:rock:
  20. mystvearn
    mystvearn any-may
    12 Feb 2009
    Thank you. Great article. I have two questions.
    1. The Enermax Pro 82+ EPR525AWT II in the affordable build is hard to find and prices are nearer to the Corsair Professional Series HX650 of the enthusiast build. Is there an alternative PSU for the affordable build?
    2. The Asus maximus V gene is a great motherboard. The motherboard manual says it supports a S/PDIF out which you buy separately but I cannot find any accessory at Asus website or online. A useless feature if you can't find something that works for it?
Tags: Add Tags
