Hardware PC Hardware Buyer's Guide September 2010
Discussion in 'Article Discussion' started by Lizard, 7 Sep 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. PandaLand
    PandaLand What's a Dremel?
    7 Sep 2010
    Still firm on single card solutions, eh?
    A 460 SLI setup seems very tempting at this point for performance/$(or £)
  3. Jedikj95
    Jedikj95 What's a Dremel?
    9 Aug 2010
    Can you let me know where you got the pricing for the enthusiastic overclooker, I'm in the process of pricing up a similar system, but can not get close to the price you are suggesting includes VAT.
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    "We played with the idea of using the reference CPU cooler for this system to leave us room for a GeForce GTX 460 1GB, but given that we’ll want to overclock that CPU, we needed to invest in a better cooler."
    Leftover from last month? You included a GTX 460 this time..
  5. javaman
    javaman May irritate Eyes
    10 May 2009
    Very good article tho I would still like to see a crossfire/SLI board as a side note recommendation for i5 builds. Its a natural upgrade path especially if does venture into multi monitor gaming.
  6. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    no mention of the much cheaper 950?
  7. mcjamweasel
    mcjamweasel What's a Dremel?
    7 Sep 2010
    For the all rounder is it not worth spending a few extra £ on an X3 440?
  8. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Cheers, fixed :)
  9. oxopo
    oxopo What's a Dremel?
    5 Sep 2010
    It's funny how it says August 2010 on every page except for the main one. ;)
  10. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    So, aside from price drops, no real changes? Can't complain, I suppose.
    Also no changes to page titles and the drop-down box. They all say August. :p
  11. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    Hmmm I still reckon that £485 isn't classed as a budget setup. £400 price point would fit it better IMO.
  12. Hustler
    Hustler Minimodder
    8 Aug 2005
    "so your next graphics card option is the £280 Radeon HD 5870."
    I dont think thats the case at all, Nvidia 470's can now be had for around £220 if you look around.......
  13. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    Yep if you try to build that system its basically 600 gone when you install Windows 7 (waits for people saying but linux is free)
    a 400 one would be nice, but it would also be quite under-powered for the majority of our needs of the people who use these forums.
  14. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    +stronger PSU
    +MB with 2x PCIe 16
    +Power consumption $$$
    and maybe even larger case
    Single card solution is better for a brand new PC.
  15. Baggpuss
    Baggpuss What's a Dremel?
    2 Jun 2009
    Surely the fact the i7 950 has dropped to within £20 of the 930 makes it the better choice?
  16. earlydoors
    earlydoors Minimodder
    12 May 2009
    £285 for an HD5870 - sounds tempting...What do you guys think?
  17. mpr
    mpr What's a Dremel?
    26 Jul 2010
    I really wish people would stop with the dual pcie x16 for multi-gpu
    x16 x x8 or even x8 x 8x is only 2-5 fps slower at budget resolutions (ie the majority of PC owners with a single monitor under 30"
    Ideally yes you would want dual 16x found on the X58s but there are also a few boards with dual x16 that aren't horribly expensive, most are workstation class though.
    There are plenty of reviews out there comparing the speeds of PCIe and GPUs and they all point to dual x8 as being sufficient for most applications.
  18. Guest-16
    Guest-16 Guest
    The problem is, for LGA1156 to get a dual x8 you need to spend a quite a lot more on a motherboard than just the basic, but excellent overclocking ones we recommend. Even some mid-range ones only have the second slot as x4 to save money on electronic switches.
  19. Xir
    Xir Modder
    26 Apr 2006
    hmmm, Premium player.
    I'd have spent the 22 pounds more on the i7 950 over the i7 930...and saved a lot more not using the 5970, but it goes either way I guess.
    Gaming Workhorse.
    The GTX460 isn't a real alternative over the 5870, at least not at 1920x1080.
    Great summary as always guys!
  20. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Only problem with that is it's a 470 :p
Tags: Add Tags
