poopheads... everyones doing red on black... gonna make my case look unoriginal... hah! I have a totally original idea! blue LEDs! ohlala... how'd you paint the frame? just a coat or two of spray paint? any primer, sanding, etc? I'm just wondering. *takes out notepad and mini tape recorder*
Then how'd he get it onto that paper transfer-thing then? It must have been on a computer at one time to get it onto the paper... Kinda guessed you two knew each other as you both answer questions on each others cases
You can order the paper just inform the manfacture the picture and size you want. It's very easy in Taiwan.
