Hardware PC Power & Cooling 750W PSUs
Discussion in 'Article Discussion' started by Guest-16, 18 Sep 2007.
  1. Guest-16
    Guest-16 Guest
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    this will be my new power supply
  3. samkiller42
    25 Apr 2006
    Looks good, and just what i need, awesome as always bindi:p
    Sam
  4. Guest-23315
    Guest-23315 Guest
    My red one should be here soon if customs don't hold it back..
  5. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I bought one of their 750w Ultra-Quiet Quad Silence jobbies a while back.
    Considering what they used to cost... the price drops have been quite dramatic since their merger with/buy out by (I can't remember which it is?) OCZ :idea:
    My 750w model cost me 'just' £99 + VAT. That's about 50% less than that same PSU would've cost me just a few months back :eeek: :hip: :clap: :rock:
  6. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    As always, PCP&C has another great unit to add to their lineup of great units. I have one of their Turbocool 510 SLI units. Loud as hell compared to others, but stable as a rock.
  7. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    A comparison between their 'connected at the source' psu's and an equivalent power rating psu from enermax or tagan would be a comparison that might justify or dismiss their claims more effectively, who knows?
    Otherwise a nice looking pair of psu's that do the job.
    peace
    fatman
  8. Guest-16
    Guest-16 Guest
    Search the site for "PSUs" and you'll see another 700-850W roundup ;)
  9. naokaji
    naokaji whatever
    8 Dec 2006
    700 - 850 W roundup here
    and the 900 - 1100 W roundup is here
  10. Guest-16
    Guest-16 Guest
    Thanks, Nao.
  11. Koolpc
    Koolpc Minimodder
    27 Jan 2005
    Good article.
  12. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    You know PCP&C were rercently aquired by OCZ, so expect future PSUs combining aesthetics, ergonomics and stunning performance. So don't all rush out and buy a PCP&C just yet. :)
  13. enughhh
    enughhh What's a Dremel?
    18 Sep 2007
    I may have to disagree with the author in regards to his dislike of a non-modular design. These are 750W power supplies potentially running huge amounts of current through those wires. Having another connector will add resistance to those wires (especially if they use a crimp connection).
    ( huge current) * (any added resistance) = voltage drop = bad
  14. samkiller42
    25 Apr 2006
    bindi, what dimensions are these PSU's?
    Cheers
    Sam
  15. Guest-16
    Guest-16 Guest
    True, but then jack up the voltage, no? OCZ have previously made PSUs with POTs you can tune yourself so it's not impossible. Plus, a hotter case from poorer airflow is just as bad as poor voltages. It's all swings and round abouts - what stops the connection to the mobo/hard drive/graphics not to be fantastic either?
    18x15x8cm :)
  16. E.E.L. Ambiense
    26 Jul 2007
    PCP&C have always argued against the modular thing. Personally, I prefer modular. I understand both sides of the argument regardless. Hell, to come to middleground I purchased a PCP&C unit made modular by Performance-PCs and warranty is still valid due to them being authorized by PCP&C to work on their units.
  17. Bogie
    Bogie Banned
    29 Apr 2007
    I have the Enermax Infinity 750W. I cant recommend it enough! 10/10
  18. Guest-16
    Guest-16 Guest
    Well the email we got from them was very positive - they understood a "modders" position even though they are staunch performance engineers, so considering PCPC own OCZ now I wouldn't be surprised if we got PCPC inside modxstream PSUs.. perhaps.
    Bogie - 720W ;)
  19. E.E.L. Ambiense
    26 Jul 2007
    I'd buy it too. PCP&C performance + OCZ looks = coolness.
  20. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Hm, as far as i can remember, topnurse used a PCPC psu in her Feeding Frenzy build ( where is she anyway?) and she clipped some of the wires, ie. opened and removed some connectors inside her psu... she even RMA'ed it after and they took it back, noted the state and said... "yep, that is our psu and it slipped through QC where it should have failed, we'll replace it, no charge" Don't hang me on the statement, but that was what i understood by her posts after.
Tags: Add Tags
