Cooling Pc switching off after 2 mins
Discussion in 'Tech Support' started by numanoid, 17 May 2016.
  1. numanoid
    numanoid Modder
    26 Apr 2009
    Hi guys
    my son-in-laws computer keeps turning itself off after aprox 2 min....i5 2500...H60...4gb tracer ram.. running windows 10, just wondering if its the H60 at fault, how would I know if the pump has packed in...it was working fine one day...the next day it kept switching itself off
    thanks guys :thumb:
  2. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Just go into the BIOS and look at the CPU temps. That will tell you if the cpu cooler is at fault.
  3. GeorgeK
    18 Sep 2010
    Definitely sounds like a heat issue to me - look in the BIOS or alternatively if it'll boot into windows try one of the usual cpu temp apps
  4. David
    7 Apr 2009
    Doesn't the H60 pump run off a fan header? Any decent monitoring software should be able to tell you the CPU temp and the pump speed.
  5. mingingbollock
    mingingbollock Minimodder
    15 Mar 2004
    Recently had H60 fail on me , same symptoms , pump was still giving a rpm signal out though
    Feel the pipes coming out of cpu block , you will soon feel the heat if it has failed
  6. numanoid
    numanoid Modder
    26 Apr 2009
    Cheers guys, appretiate the help
  7. numanoid
    numanoid Modder
    26 Apr 2009
    UPDATE guys
    I started the pc, went into the bios, watched the cpu temp climb all the way to 88c....seems the H60 is a tad dodgy
    thank you guys ...
  8. Pookie
    4 May 2010
    Glad to hear it's something simple to sort out :thumb:
  9. numanoid
    numanoid Modder
    26 Apr 2009
    Yes pookie, cheers matey
  10. GeorgeK
    18 Sep 2010
    Try reseating it first and see if that helps - if not then new cooler time :thumb:
  11. numanoid
    numanoid Modder
    26 Apr 2009
    thanks George will do matey
  12. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    If you're passing Preston drop in and I'll fit your replacement cooler (if you buy one) with some thermal grizzly kryonaut for free bud :).
  13. numanoid
    numanoid Modder
    26 Apr 2009
    Thanks matey :thumb:
    Appretiate that matey, not even sure if he has ordered a cooler yet, his pc is sat here lol, im sure I can feel a slight vibration when I put a finger on the cpu pump....can't be sure though
    thanks again my friend
    take care
  14. Vault-Tec
    30 Aug 2015
    If you run the cooler without anything else you should be able to put your ear to it. The pump may have jammed. Now you can take them apart but it's messy, fiddly and you will need a res after you put it back together.
