Networks PC to Pc connection
Discussion in 'Hardware' started by JoeStrummer, 5 Jul 2004.
  1. JoeStrummer
    JoeStrummer What's a Dremel?
    5 Jul 2004
    I am trying to connect to computers together to transfer some files. I am running windows xp pro on both computers. I have an ethernet crossover cable and I pluged it into both computers. Now how do I transfer files from one computer to the other?
    Thanks in advance
  2. m4rk3d
    m4rk3d Minimodder
    15 May 2004
    Try this thread , it gives a nice, simple introduction to windows simple file sharing.
  3. JoeStrummer
    5 Jul 2004
    I tried that and I got to the part where try to view the shared folders on the other computers and i get an error message saying, "the network path was not found"
    any suggestions? :confused:
  4. Xipher
    Xipher What's a Dremel?
    25 Apr 2004
    Check the IP addresses, as long as they are on the same subnet, the should be able to see each other. You can test that with the ping command.
