Other PC to run some old games
Discussion in 'Hardware' started by Xcellente, 21 Dec 2011.
  1. Xcellente
    Xcellente What's a Dremel?
    27 Sep 2011
    Stuff like, COD, house of the dead, quake 2, the original unreal tournament, xiii and whatnot
    looking on ebay for some old xp comp, what if i got some old P4 and took it to 4.0Ghz or is that impossible?
    found this hes sold 3 advertises it as gaming dual core and can take a GT520
    http://www.ebay.co.uk/itm/Fast-P4-H...t=UK_Computing_DesktopPCs&hash=item415fa8b328
    Old games dont run on windows 7 i tried and errors and stuff so what do i do
  2. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    You might need a Win 98 PC to run some really old games as they won't even work on XP. I recently made a Win 98 PC for all my pre XP games.
    edit: I hope this isn't another of your troll threads that i've stumbled into
  3. Xcellente
    27 Sep 2011
    oh no does that mean i need a CRT monitor too? i may aswell get a PS1 again =P
  4. Xcellente
    27 Sep 2011
    how did you manage that now?
  5. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Does compatibilty mode not work?
    What about a virtual machine?
    As for clocked a P4 to 4ghz, you'd need to hefty cooling, dont think there's many mono's that can handle the overclock but I could be wrong, just never heard of it much
  6. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Virtual machines are a pain in the ass for games. The original Call of Duty is happy on Windows 7, though.
    About the only games I've had issues with are Homeworld (Really doesn't like any GPU from about 2007-onwards) and Grim Fandango (That shiz just needs Windows 98.)
  7. Xcellente
    27 Sep 2011
    does anyone rememeber that game, Typing of the dead where you had to type to kill the zombies
  8. Deders
    Deders Modder
    14 Nov 2010
    You won't need to run a P4 at 4GHz to run those games, I remember playing most of them on a P2 350MHz with no issue.
    To be honest you could probably install XP or 98SE on to a separate hard drive in your current computer just for those games.
    Advertising that PC as Powerful with 2x 3GHz is a bit over the top, it would be more like 1.2x 3GHz if you are lucky.
    It probably could run a 520, basically you'd need to make sure that you choose a card that doesn't need any extra power then the PCIe slot would provide, I.E. no 6 or 8 pin PCie connectors.
    Any monitor should plug in so long as it has the right connector.
  9. Deders
    Deders Modder
    14 Nov 2010
    Played both of them, completed homeworld running in widescreen on a 9800GTX+ SLI setup not too long ago, and there is a 32 bit installer for Grim Fandango floating around the web.
  10. .//TuNdRa
    12 Feb 2011
    98se on an i5 2500? That'd be interesting to see. I don't think the drivers exist for XP/98 for anything new than the GTX 200 series, though.
    Hokay. Seems Homeworld just doesn't like my PC. Flickering menus and have to force Direct Sound off, else it just grinds to a halt somewhere.
  11. Deders
    Deders Modder
    14 Nov 2010
    Good point, if you were to go down the old PC route you'd want to get an older graphics card, like a 6600GT that has drivers.
  12. KidMod-Southpaw
    28 Sep 2010
  13. Xcellente
    27 Sep 2011
  14. GeorgeStorm
    16 Dec 2008
    If you want to play typing of the dead, then you can, I only got it the other week, runs fine on W7?
  15. Xcellente
    27 Sep 2011
    i dont think there is any point in it just for a few games unless i could play them on my current pc of course
  16. .//TuNdRa
    12 Feb 2011
    Virtualisation might work. I know VirtualBox does support D3D rendering inside a Virtual Machine. But it's glitchy. I tend not to bother because it's so unstable.
  17. docodine
    docodine killed a guy once
    10 Feb 2007
    Typing of the Dead runs fine on Win7
  18. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    4 player pod cast played it quite abit on youtube, love it though, its my fancy dress of choice :p
  19. boltonuk007
    boltonuk007 What's a Dremel?
    29 Sep 2011
    why dont you just partition your HDD and install an older OS on there? seems easier than buying and finding room for another machine
  20. Instagib
    Instagib Minimodder
    12 Mar 2010
    If he's running AHCI mode on his hdd's then that just opens up a whole new can of worms.
